Question about Lavelle Industries Korky& Universal Toilet Repair Kit
Sanibest toilet is humming and won't flush - Lavelle Industries Korky& Universal Toilet Repair Kit
The toilet is filling up in the pan when flushing
The most likely causes based upon the little information you have provided are that either the toilet is partially blocked or the air vent in the SaniFlo unit is clogged up.
Try unblocking the toilet first, and if that doesn't work you must remove and clean the air vent (on most models it's below the carbon filter).
Jun 27, 2011 | Saniflo 013/003/005 Sanibest Toilet with...
My Sanilflo system is fed by a toilet and a sink. When the sink fills it to operating the grinder runs for about 5 seconds and switches off. When the toilet is flushed (no solids) the grinder runs for...
The amount of time that the pump operates is determined by the amount of water that is drained into the unit. If the amount of water from the sink is less them the amount flushed then the pump will run accordingly.
Mar 06, 2011 | Saniflo SANIBEST Pump Macerator Grinder...
Is sanibest energy efficent
Not any more than any other 1.6 gallon flush tiolet.
Feb 11, 2011 | Saniflo SaniBest-Elongated SaniBest...
My sanibest is just humming. I am assuming that the motor is clogged with something disgusting. I have a toilet, sink, and bathtub going into the sanibest. Unit stopped working as soon as tub was draining...
Bail out as much as you can through the toilet bowl. Unfortunately this is a messy job regardless and you will still need newspaper on hand.
If you lower the water level below that of the rubber gasket connecting it to the toilet though, you will be able to undo the jubilee clip holding this and slide the unit away from the toilet, hopefully without spilling much waste water.
If you can dislodge the blockage from this angle, great. If not, you might also have to take the lid off by depressing the plastic clips on each side and accessing the chamber from the top.
Oct 17, 2010 | Saniflo Sanibest macerator with multiple...
SMELLS WHEN I FLUSH
this brand of toilet needs to be vented to the outside. If you left the pipe open or the seals are not intact it will emit a smell when flushed.
Sep 08, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Must flush saniflo multiple times to get rid of all waste.
loosen chain to plug in the back of the toilet it is too low so not much water is needed to flush
Jun 03, 2010 | Saniflo Sanibest Grinder Pump Only 013
Grinder wont turn and toilet not flushing
Disconnect the power and pull the pump out and examine the pump. Simple and easy!
May 23, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Sanibest toilet is LOUD when flushed
Shut down the power and pull the pump from the unit and give it a exam. There might be something as simple as a item that was flushed down the toilet (pencil, pens, combs, etc.) or just a hair clump. Check that the float is free to track fully up and down. Good Luck!
May 17, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Toilet pumps bursts of water
either your fill valve needs replaced or your flush valve needs replaced
May 13, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Lavelle Industries Korky& Universal Toilet Repair Kit  Logo
85 people viewed this question
Top Lavelle Industries Home Experts
john h
Tom Chichester
Are you a Lavelle Industries Home Expert? Answer questions, earn points and help others
