Modine pa75a I have a Modine natural gas heater that needs a replacement of a Robertshaw gas valve. I was able to get ithe following off the valve: 120VAC - .034A - 50/60 HZ. Do you know what model number valve I would need?
  • 3239 Answers
SOURCE: I need a gas valve for a Dayton model 3E473A wall furnace
you can look for a gas that we go in place of the one you have, try national energy they sell gas valves and should have one to fit your heater , i would change the thermocouple as well .
hope this helps
Posted on Dec 08, 2008
  • 4 Answers
SOURCE: rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Posted on Feb 05, 2009
steve_lima
  • 181 Answers
SOURCE: I have 5 dayton heaters the model number is 3E371, they were made
the proble with converting them is it's not just the orffice.you need to take out the fuel valves.replace the feed line to the orffice,you need to get the correct regulators that attaches to the lpg tank.cost isn't worth doing the change over
Posted on Mar 17, 2009
  • 116 Answers
SOURCE: how does one troubleshoot and repair a gas control
some gas valves have a flame height adjustment but if no gas replace valve
Posted on Jul 09, 2009
  • 3239 Answers
SOURCE: ? Replacement part for an obsolete Williams gas valve P100172A
Hi try national energy they should be able to tell you the right valve for this , the thermopile should read between 500 and 300 mille volts
Posted on Feb 10, 2010
HOW TO TROUBLESHOOT ROBERTSHAW GAS VALVE
check the pressure switch if voltage to both sides its ok then check the gas valve to see if voltage at brown and yellow wires
Oct 14, 2014 | Honeywell Robertshaw Grayson Gas Valve Lp...
Unit will not light. want electric print of the control circuit.
do u require a manual? plse also provide the model number of ur device
Oct 23, 2008 | Heating & Cooling
Hello I have a robertshaw 7100 see. Gas valve on me furnace and would like to know if it has both Nat. And propane orficess in it and how to change it from one to the other. Thanks brad
I'm not sure if the orifice can be changed on your valve, that is the only difference between natural gas and propane. I recommend calling your local plumbing supply store for exact specs but the gas valve shouldn't be much $$$
Aug 18, 2014 | Heating & Cooling
How change robertshaw 110-32f
Turn off gas to the heater close water supply drain the water out of heater.Remove pilot tube assembly remove thermocouple/or thermopile assembly disconnect gas at the union and remove from valve. Use wrench that fits the hex shaped nut that holds the aquastat and water heater in the tapping. Usually the wrench size is 3/4" or 7/8" depending on the unit.
Put pipe dope on the male thread of the valve and keep it off the aquastat bulb, and rethread into the tapping.
Replace the ilot assembly being sure it was not damaged when it was remover if it was damaged replace it. replace the thermocouple/powerpile assembly replace the gas piping from the valve being sure to use pipe dope on the fittings and tighten them enough so they do not leak. Do not use teflon tape because it could get into the gas valve and cause problems.Test the gas piping for leaking do a tight test on the meter if possible or test with testing fluid and look for bubbles or use a gas leak detector that sniffs for gas and beeps when it detects a leak
Fill the water heater up with cold water and check to be sure there are no leaks at the thread where the valve is threaded into the tapping. Open a hot water faucet and be sure the heater is full of water.
Light the pilot and turn the gas on set to the temp that is best suited to you..
Apr 06, 2014 | Robertshaw 110-32F/110-326 Natural Gas...
Modine Hot Dawg heater - no heat
that sounds like the limit look for a little round thing with two wires with a button between the wires push it to reset it but there could be several of them even one buy the blower motor there is also a high limit in the center of the furnace all you see is two wires if that one is out you have to remove it two screws then just drop it on the floor it will free the numeral bymetal inside put it back on and you should begood
Nov 23, 2013 | Modine Hot Dawg Heater Model HDS - Natural...
How to replace a robertshaw gas control valve
Robert Shaw water heater gas control valve?
Copy following link for replacement of each type of gas control and related troubleshoot.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Mar 28, 2013 | Rheem Waterheater Natural Gas Valve
Pilot doesn't stay lit
1) Copy following link to troubleshoot by type of gas control valve:
2) Replace gas control valve.
Mar 02, 2013 | Rheem Water Heaters
How do I light the pilot on my Modine PA105AB?
Look on the side or bottom there will be a little circular door held on with one screw it will swing from side to side there should be a long wire with a hook on the end that looks like a key ring this is used for holding the match if you can't find the match holder in the bottom of you unit find some way to get the match up to the pilot head then turn your gas valve to pilot position and push in on the button while holding the button in light the match hold it to the pilot head once the fire lights continue to hold the button down for 10 seconds then instantly let off the button and turn the knob to the on position and your set .
Hope this helps......
Nov 18, 2010 | Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
