Question about Garden
Walker mower was mowing it stopped and wont start with the key i jump the started it will start for a couple seconds then shut off again
SOURCE: 1998 ford contour start up, alternator? battery?
Sounds to me like you drained your donor battery to the point where you can't jumpstart your car anymore. If you jump a car and it runs for a little bit but then dies that means your alternator is toast. If it was a bad ground, you would see sparks or a fire... Your battery only starts the car, once it is running your alternator supplies the electrical system and charges your battery back up. If you need more in depth help in replacing the alternator go to www.contour.org and get on the forums.
Posted on Oct 27, 2008
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
  • 69 Answers
SOURCE: lawn mower won't work
Clean the carb out.
Posted on May 18, 2009
wadembly
  • 462 Answers
SOURCE: I have a craftsman electric key start lawn mower.
the battery probably got over charge & shorted the cells the tractor should charge the battery as it runs if it was equiped with electric start the battery charger more than likely over charged it killing the battery
Posted on Jun 08, 2009
wadembly
  • 462 Answers
SOURCE: craftsman DYT 4000, 24 hp 48
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Posted on Jun 14, 2009
Walker mower
Your ignition switch is bad. The contacts inside are not making good connection to send signal to starter solenoid to start engine. Now the run position contacts are bad causing the engine to shut off. If the engine cuts out on you again, wiggle the key in the ignition at the same time start the engine using your screw driver. If the engine starts back up again, wiggle the ignition to see if the engine hesitates and stalls out again. If so, replace ignition switch assembly.
Sep 25, 2013 | Garden
Huskee LT 4200 Lawn Tractor I had to jump my mower today and mowed for 45 minutes, turned it off, added gas, started mowing again for 30 minutes, turned it off and now it won't start, turn over or...
A couple of possibilities, either the main fuse has blown, they are normally an auto motive design and located undrt the the hood of the machine, or the start solinoid has burnt out.
Jun 18, 2013 | Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
Two years ago, my mower (cub cadet lt1042) wouldn't start. Replaced the solenoid switch and it worked the rest of that summer and the first half of last summer. The middle of last summer, I mowed part of...
hard to say, I would make sure the inline fuse is good, then use a vehicle and jump start the mower. I am sure you know how to ensure the mower is ready to start, so we won't cover the pto,brake,etc. Good Luck Tim
Mar 26, 2011 | Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Toro lawn tractor
There is a switch on the seat and one on the brake pedal
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
1999 Chevy S10 cranks but wont start
A very common problem on the 99 S10 is a leaky fuel pressure regulator in the intake plenum.What happens is when the truck sits for a few hours or more the regulator leaks all of the fuel in the fuel injection system into the intake air plenum. This does 2 things, 1 it has no fuel pressure when starting and 2 it floods the air intake with raw fuel. Sometimes if you turn the key on wait 3 seconds then turn key off then turn key back on and just turn key to crank starter for a split second and wait 3 seconds.do this 3 times to repressurize fuel system then crank to start(you will hear fuel pump buzz each time you do this.also you may have leaky fuel injectors. Try to crank engine with the gas pedel to the floor. This will tell the computer to stop spraying fuel trhough the injectors and it will start. Joe ASE Master Tech
Mar 04, 2009 | 1999 Chevrolet S-10 Pickup
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
