Question about Black & Decker MX55 PowerPro Hand Mixer
Gear parts for Cooks HM820 - Black & Decker MX55 PowerPro Hand Mixer
How do i order parts for cooks mixer
Check with a local appliance parts supplier.
Oct 19, 2016 | Food Mixers
Looking for a circuit board for a cooks mixer sm248
Where can I get attachments for my Cooks JC Penny stand mixer?
Oct 12, 2016 | Food Mixers
Need to replace the whisk.were to find for a cooks sm248
Search the internet for:
Make + Model + the word "parts" or "accessories"
Mar 17, 2016 | Food Mixers
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Hobart A200 mixer. 1st gear has no torque, I can stop it by hand. I found the key sheared on the low speed gear(flat gear, beveled gear part wasn't sheared). I replaced the key, & it sheared it again...
Ed, if you continue to do it yourself, the end result will be tossing good money out. Have a professional check the system and save the unit from permanent damage. Chipping parts of a gear off means a serious resistance force or action has occurred. One force is slowing down as the other is speeding up. Gear alignment can be moved off center, or a sudden application (sudden stop or start) can damage the least resistant parts. For example, when a hook turns within the mixing chamber and the resistance of the content is too great on the turning shaft and gears, which ever part is weakest will break. Complicated I guess.
Mar 01, 2014 | Hobart A200 Stand Mixer
Cooks model sm 248 mixing parts and break down on parts along with owners manual or opereting manual
i have searched the web and cannot find a instructions Manual for the Cooks mixer Model sm248... any help?
Nov 13, 2011 | Cook's Essentials 700 Watts CESM100 Pro...
Need owners manual for Cooks 12 speed 5-qt. 700W stand mixer. Actually need a replacement balloon (wire) whisk and can't find manual for a telephone number nor can I find any replacement parts for this...
Hi, SCOOTERBUG39 It seems that your Cooks mixer is sold by JCPenny, and they seem to be pretty closed lipped about Owner and Parts manuals, but I was able to find the warranty information for your machine, which I've extracted below. FYI, the toll-free number to the JCPenny Product Service Department is: 1-800-933-7115. A live person there, might be able to help you.
WARRANTY INFORMATION
ITEM DESCRIPTIONS: Cooks 5-qt. Stand Mixer WARRANTY REF NBR: P1000
COOKS 5-QT. STAND MIXER
P1000 P1000 SUB.780,781,782 August 2005 COOK'S Limited Warranty Limited One (1) Year Warranty J. C. Penney Corporation, Inc. (JCPenney) warrants this product to be free of defects in material and workmanship for a period of one (1) Year from the date of original purchase (the "Warranty Period"). Dated proof of purchase such as a bill of sale is required to establish warranty eligibility. If the product fails to perform due to a defect in materials or workmanship during the Warranty Period, JCPenney will repair or, at JCPenney's option, replace the merchandise with the same or comparable item at no charge to you for parts or labor. In the event that the product can not be repaired and a suitable replacement item is not available, JCPenney will refund the original purchase price shown on your proof of purchase.
To Obtain Warranty Service In the event that your product requires repair during the Warranty Period, contact your nearest JCPenney retail store or call JCPenney Product Service Dept. (800) 933-7115 for information regarding where to obtain warranty service. What This Warranty Does Not Cover This warranty does not cover (a) damage due to acts of nature, including but not limited to, lightning, wind, or flood; (b) damage due to accident; (c) damage due to neglect, abuse, misuse, improper installation, mishandling, or failure to follow instructions provided in the product's Owners Guide; (d) damage resulting from alteration, improper maintenance, or repair by other than JCPenney authorized agent; (e) labor charges for installation, or for removal and reinstallation of the item for servicing; (f) non-rechargeable batteries, consumables, normal wear parts; and/or (g) items used in commercial applications.
REPAIR OR REPLACEMENT AS PROVIDED IN THIS EXPRESS WARRANTY IS THE PURCHASER'S EXCLUSIVE WARRANTY REMEDY. ALL IMPLIED WARRANTIES INCLUDING THE WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE LIMITED IN DURATION TO THE PERIOD OF THIS LIMITED WARRANTY. IN NO EVENT SHALL JCPENNEY BE RESPONSIBLE FOR ANY LOSS OR DAMAGE, INCLUDING DIRECT, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES RESULTING FROM THE USE OR INABILITY TO USE THIS PRODUCT. Some states do not allow limitations on how long an implied warranty lasts or the exclusion or limitation of incidental or consequential damage so the above limitations or exclusions may not apply to you. This Warranty gives you specific legal rights and you may also have other rights which vary from state to state. J. C. Penney Corporation, Inc. 6501 Legacy Drive Plano, Texas 75024
Hopefully this will help point you in the right direction. Howard - Burke, VA
If this solution has helped, please rate it, thanks! - hslincoln
Dec 01, 2009 | Food Mixers
Replacement parts for Wolfgang Puck stand up mixer
Very close; stand mixer parts (included accessories and manual only) can be accessed from this page:
http://www.wpcookware.com/categories.asp?cat=32
Just select your mixer's part number (located on a sticker inside the base) and click the link for a list of available parts. You will have to create an account to see anything useful, but all they ask for is your name, a password and an email address. When adding items to your shopping cart, be sure to check the 'Select Item' box. The ordering page will ask for the usual info. Prices are reasonable, but beware the shipping cost!
Jun 20, 2008 | Wolfgang Puck Stand Mixer
Black & Decker MX55 PowerPro Hand Mixer Logo
Top Black & Decker Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Karl Kittsteiner
Are you a Black & Decker Food Mixer Expert? Answer questions, earn points and help others
