Question about Woods WD25G Dehumidifier
Coils are icing up after I replaced my fan motor.
Last week the fan motor on my Wood's dehumifier burned out as a result of a completely plugged air filter. I replaced the motor last night. I turned on the dehumidifier and let it run for awhile expecting to see condensation droplets when I returned. Instead the coils were completely iced up. To the best of my knowledge this has never happened before.
  • 148 Answers
Fan blade could be backwards
Posted on May 10, 2009
The motor is still running fine, but the dehumidifier is no longer extracting water from the air and the water container is not filling.
John, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 19, 2011 | Haier 45-Pint Dehumidifier
Maytag Model M7DH65B2A will not dehumidify and only the fan blows cool air but not taking humidiity out of the air. How should the dehumifier be fixed?
Martin, you may not need to have it repaired if you check and troubleshoot, these 5 basic things that can cause this problem. All are solvable. Please take note of # 1.
2. Air intake filter is dirty or clogged. Turn unit OFF, remove and clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
5. Ambient air temperature at floor level is between 40 - 60 degrees F. Dehumidifiers do not work
well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to
basement applications, where the air temperature at floor level is colder than at shoulder level.
Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Jun 20, 2011 | Maytag M7DH65B2A Dehumidifier
Why is my dehumidifier icing up.
The room temperature is probably too cold, or there's poor airflow
Here's some info that should help you figure out what's causing the problem:
If the evaporator coil is frosting completely and evenly, the most common cause is that the room temperature is too cold. Most dehumidifiers are not meant to be used when the room temperature drops much below 70°F and certainly not below 65°F (depending on humidity). There are however some models called "basement" dehumidifiers which are.
Another possible cause on standard models is poor air flow through the unit. If the fan motor is not turning fast enough (or at all) or the evaporator, condenser or filter (if used) being plugged can also cause this symptom .
May 13, 2011 | Goldstar DH304 Dehumidifier
Our dehumidifier has formed a sheet of ice amongst the coils and will no longer pull moisture from the air. The hole from which the water drips is completely iced over. It is 70degrees in the room and...
Turn the unit OFF and unplug it from the wall. Allow it to thoroughly thaw and remove the humidifiers cabinet to expose the cooling coils. Clean those thoroughly and coat with a very light coating of WD40. Reassemble the humidifier and turn it ON. Set your humidity control at 50% and allow the unit to run for at least one hour. Check for water collection in the bucket and for any signs of icing, after one hour. If water is in the collection bucket and no signs of icing, lower the humidity to 45% and continue. If you not any signs of icing, watch the unit, as you need to know if it automatically goes into defrost mode. The compressor should shut off, but the fan will continue to run until defrosting is completed. If it doesn't the auto defrost sensor has failed and will need to be replaced.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
May 08, 2011 | Dehumidifiers
Hi I have a Danby DDR3008EE dehumifier that is putting water on floor There is ice inside where the filter is. What should we do besides turn off and let melt?
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Good luck.
Aug 14, 2010 | Danby DDR3008EE Dehumidifier
My dehumidifier ices up. It will not remove moisture when it ices up. What can I do and is it under warranty?
Take care.
Aug 10, 2010 | Fedders A7DH45B2A Dehumidifier
I have a LG LHD45 EL dehumifier, stopped working suddenly
Check the glass fuse on the circuit board inside the power supply at back of unit (have to take off cabinet)
Dec 03, 2009 | LG LHD45EL Dehumidifier
Dehumidifier runs but doesn't produce water
Your dehumidifier has a circulating fan that draws the room air over the coils. If there's no air movement out the front or back of the unit, the fan motor may be burned out or stuck, or the fan blade may be broken. If so, you need to replace the fan motor or the fan blade.
Sep 04, 2009 | Kenmore 5230 Dehumidifier
Fan runs but no water, I suspect refrigerant leak, coils are clean, so is filter
My experiance when I ask my Heating and air conditioning guys when they were out serviceing my home air conditionion was a resounding NO not cost effective these units are practically considered throw away,with no value after 3-5 years no matter what price range and this is true. They say the cost is purchacing and adding the valve needed to refill. Just another prime example of total waste and disposable world we live in.
JTHOMEFIX
Sep 14, 2008 | Fedders A7DH45B2A Dehumidifier
Woods WD25G Dehumidifier Logo
290 people viewed this question
Top Woods Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Woods Dehumidifier Expert? Answer questions, earn points and help others
