Question about Zoom (56600000) Router
Slow Access Speed to the Internet
Hi all, first post so be nice.
I've got a 2Meg broadband speed connection and recently I've found that my connection to the internet is really slow.  I've checked on the ADSL status in the router and it says it's 2,043 kbps but when I do broadband speed tests I am only getting less than 400kbps.  I have called my ISP and they say there's nothing wrong with my line and the ADSL status in the router shows this to be true.  Also, it can't be this computer as it's happening on my two laptops too so the only thing it can be is the router.
This has only started happening over the last 1.5 weeks.
Does anyone have any idea of what it can be?
  • 1 more comment
  • Giania Oct 10, 2007
    Should add that it's a Zoom X6 router I have.
  • Giania Oct 12, 2007
    Sorry, forgot to update this when I fixed it.  I had tried a few things and eventually I got it fixed by updating the firmware to the newest version then a hard reset.  It's done the trick and I'm back up to my 2M.
    Thanks for your replies.
  • Giania Oct 20, 2007
    Yes it is ramji.  After a flash and hard reset.  Thanks for your comments.
  • 261 Answers
U test your internet speed here!...
Posted on Aug 07, 2009
    President:
  • 2,360 Answers
Check the modem
Posted on Dec 17, 2010
    Scholar:
  • 193 Answers
Fire wall on the router disable the fire wall and delete all the temp files and cookies and clear history
Posted on Oct 12, 2007
  • ramji duraiswamy Oct 12, 2007
    or try this change the DNS-to this in both laptop-
    DNS 1-- 4.2.2.1
    DNS 2-- 4.2.2.2
    AND REBOOT
  • ramji duraiswamy Oct 16, 2007
    is it working fine
SOURCE:
Broadband is what kinda way to connect internet
"Broadband" is usually used as a synonym for "high-speed." The FCC, for example, defines "broadband" as a connection speed of at least 25 Mbps. Here are some common broadband connection types in the U.S.:
https://www.fcc.gov/encyclopedia/types-broadband-connections
Originally, broadband meant transmission using multiple frequencies/traffic types. The opposite was baseband, where only one channel of transmission in on a wire. Ethernet, for example, is a baseband transmission. (Ever seen flavors of Ethernet described using 100-BaseTX or 1000-BaseLX? The "Base" is short for "baseband.") But you would really only use broadband in that way if you were having an engineering discussion about transmission technologies.
Jun 05, 2015 | Computers & Internet
Why is my google moving slow?google
Hi Jacqelyn
Could be a number of things, please could you let us know what Internet Browser you are using and also check the speed of your internet connection.
Speedtest net by Ookla The Global Broadband Speed Test
Thanks
Andrew
Jan 08, 2014 | Computers & Internet
I've been experiencing internet slowdowns from my regular service.
You've been capped. Contact customer service of your isp
Oct 19, 2012 | aol.ca
How to increase broadband speed in windows vista home premium
Contact your internet service provider and pay for a speed upgrade.
Mar 03, 2010 | Microsoft Internet Explorer 7
Broadband
Sounds it is your modem. I had a similar issue with my old one. I had a westell 6100F and now have a 6100G that helped. My company had to replace about 150 of line about 1000 Ft away from my house. The cable was in a storm drain and it was getting wet and interupting my internat connection.
Oct 17, 2009 | Computers & Internet
Download speed slows when router is on line.
If the router is offline then your not downloading anything, most down loads start fast then fall to a level your pc can handle, aka your connection speed.
Apr 07, 2009 | Linksys Wireless-G Broadband Router
My internet speed is slow.I connect it via bluetooth.
by any means even if the configuration of the system is also very good but still with the bluetooth you will not get the connectctivity speed like the broadband and that is same as with the wireless also you will not get the speed like you get from the broadband connection . as this is just the virtual connection with just give you the emergency support not like as usual cbroadband connectivity.
so that cannot be increased .
Mar 26, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Fast browsing slow download!!!
are you connected to a router if you are some times the router will slow the download speed because it has to run throught the router to recignize the ip address every time
Jun 19, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Xbox Live Problems
Need more information in order to resolve this issue! For instance have you made any changes to your network? Ex. Firewall, passwords, usernames, etc. Everytime you make a change to your network it changes something in the direction that two devices communicate with one another. You may need to run a specific software to have your xbox recognize your new upgrade!
Nov 24, 2007 | Belkin (F5D7231UK4) Wireless Router
Netgear router dg834gt
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results. your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP. If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds. Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Jun 18, 2007 | NetGear DG834G Router
Zoom (56600000) Router Logo
264 people viewed this question
Top Zoom Computers & Internet Experts
Paul Castley
Paul Castley
Prashant M
Prashant M
Ekse
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
