Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
Comment demonter un ampli fender bullet 150 pour changer un fusible
Clean or replace sticky knobs on passport fender 150 pro?
Clean first then if it still has a problem replace.
Dec 12, 2016 | Fender Music
MY SOUNDCRAFT EFX8 IS CAUSING MY AMPLIFIER LIMITER TO KICK IN, AND CAUSING SOUND CUT OUT
Usually is because the signal exceed the input limit of the ampli.
I don't know which ampli do you use, but it should be a pro ampli with balanced inputs correctly able to manage +4 dB professional signals.
Try not to exceed 0dB in the master section of your mixer and let me know.
Oct 14, 2015 | Soundcraft Music
How much is my Fender electric guitar worth?
It varies depending on condition and your particular market, but in my market a used Squier Standard in good shape runs $125-150.
Nov 12, 2014 | Fender Music
Fender passport 150 pro- Bought to uses for "Bike Nights" Plaing cd palyer in small retail parking lots. Volume is too low, when ever I try to put input level beyond halfway,,, I get...
You are in danger of popping the amp. The Fender passport 150 would be capable of covering about only a 20 foot by 20 foot area. If your area is bigger than that, you need more power and certainly bigger speakers. I would NOT recommend the larger Passport systems as the speakers are too directive for what sounds like your use... also there are reliability issues.
Aug 05, 2011 | Fender Passport Deluxe 500watt Sound...
I just bought a fender passport 150 and it isn't very loud and the channel lights aren't even coming on when I plug in my guitar or my mic. You can hear the guitar and mic but only when the volume...
Turn down the VIP knob and try it. This is on channel 1 for announcement voice overs overriding everything. It has a threshhold setting for adjusting that. Here is the manual for it.
http://support.fender.com/manuals/pro_audio/Passport_P150_manual.pdf
Jun 05, 2011 | Fender Passport 150 Pro 150-Watt Class-D...
Need Fender Squier Bullet 1 w/3 pickups, 1 vol, 1 tone wire diag
I think this is what you are looking for:http://www.squierguitars.com/pdf/current/Strat/Bullet%20Strat%20with%20tremolo-%20Service.pdf Please let me know if this helps.
Dec 07, 2009 | Fender Squier Std Strat Mn Car
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
203 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
