Question about Krups V65 Iron
V65 iron not turning on - Krups V65 Iron
How to remove the cover of v65 iron
How to open the Krups V65 iron
There are no clearly visible screws. Below the "secret" unveiled:
you have to pull the cover in the arrow direction, disengaging in circled positions.
After that, pull out the upper rubber keys, you will see the screw below:
Feb 25, 2012 | Krups V65 Iron
The iron is not getting warm indicator stops on first level
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Apr 10, 2010 | Krups V65 Iron
Rowenta surfline iron turned off and won't go back on.
heatman101
Jan 27, 2010 | Rowenta Surfline Iron DE-333 Iron
Iron will not turn on
heatman101
Jan 27, 2010 | Euro-Pro G1490 Continuous Iron
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
Rowenta Steam and pressure iron does not turn on
heatman101
Apr 20, 2009 | Rowenta DG-980 Iron
Why isn't my Iron heating up? Just finished filling my Krups V65 iron with water. Was ironing linen shirt on linen setting, all of a sudden, heat dropped all the way down to light one (very low heat) and...
I do believe the thermostat is defective.All the iron have a small thermastat top control the temperature and is working like a switch.If the switch don`t work get stuck on the same position.Unfortunatly sometimes is better get a new one themn fix an old one but this is The Market and nothing i can do personally.Also make sure the thermostat knob is working properly.If you hear a click when you turn is ok.
Good Luck
Jun 12, 2008 | Irons
Rust
No. The machine is not gone but you may have to replace the steam compartment of the machine.. You can also try cleaning the rust.. You will need to get a pair of gloves open the steam compartment and clean the rusted area with dilute oxalic acid.. It will work more often than not..
Good Luck!
Sai.
Mar 15, 2008 | Krups V65 Iron
Krups V65 Iron Logo
Top Krups Irons Experts
Are you a Krups Iron Expert? Answer questions, earn points and help others
