HDMI inputs not recognizing any device
HDMI inputs not working
  • kc5ile May 09, 2009
    The system worked just fine on monday, and on Tuesday it didn't (I have had it for about a year now).  I read somewhere about the ports being deactivated due to a sensor???  I just can't reset the ports.  All of the ways to get into the service menu to reset them does not work as my remote does not have the combination's required, ie Sleep timer Button.
  • 67 Answers
Make sure the corect signal is being used progresive pcm etc
Posted on May 08, 2009
Vizio Model M470SV HDMI port nor working (won't recognize dvd player,Xbox,play station etc)
This unit has four HDMI ports. Input is not automatically set to the port that your devices are connected to. Take a look at the markings that correspond to the port that your peripherals are connected to, then use the Remote Control to change the respective HDMI port.
With your external device connected and turned on, press the HDMI button on the Remote Control several times in succession until the proper HDMI port is displayed. Output from your device should now be displayed on the screen.
Nov 27, 2014 | Vizio Televison & Video
Sharp LC-32sb24u hdmi not working
You have to tell the TV which HDMI input to use. ie you should be able to press a button on your remote to do this. On my tv we can choose between 4 different HDMI inputs via the remote.
Dec 23, 2013 | Televison & Video
No video from HDMI inputs, it does recognize the any-net but no picture at all
Sometimes the HDMI needs a particular order to recognize a device. You may need to have the DVD turned on before the tv or visa versa for it to work.
Nov 30, 2013 | Samsung UN55C7000 55 in. TV
HDMI inputs
Hello, plug in HDMI's and turn on the device's and unplug the tv and plug it back in and turn the tv on and see if it "finds" them. See if that works, usually does....tks
Nov 08, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Not recognizing hdmi
Well, all joking aside, the HDMI cable first needs to be connected to the device and the TV and both on. Next the TV input settings needs to be checked to make sure that the right input has been selected. Finally, make sure that the device that you are wanting to display OUT to the TV is plugged into the HDMI OUT if said device has multiple in and outputs.
Oct 30, 2013 | LG Televison & Video
When i go to hook up a hdmi cable to my philips flat screen it wont recognize that i have a hdmi plugged into it. so what could that be the tv? the hdmi works with my other tv though
This model has 4 HDMI inputs, do you get same problem in each HDMI input?
Did you checked HDMI input with any other video source like dvd player or PS3 etc instead of cable box?
Below are few helpful tips to connect HDMI input..
1. Ensure that your HDMI cable is certified.
2. Press SOURCE on the remote control to switch to another source and then switch back to the HDMI source.
3. Reset the accessory device and the TV.
• Turn on the TV
• Select the HDMI channel
• Turn on the accessory device
4. While the TV and the accessory device are powered on, unplug either end of the HDMI cable and then reinsert the cable.
Try above options and if tv still does not show picture of any video source through HDMI then it seems problem of HDMI processor located on main board, visual check is needed by qualified tech or call Philips if tv is under warranty.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Philips 42PFL7403D/27 42 in. LCD TV
Box does not recognize hdmi
Hello, Daniel Busa with Dish Network here. The easiest way to tell if your box has a bad hdmi port onthe backm, is to remove the hdmi cord from the receiver and connect it to a blue ray player or other device. If it works the port is most likely bad. Otherwise I would recommend a hard reset, if you have a surround sound receiver cycle the inputs on it and make sure everything is on the proper input/source.
Sep 16, 2010 | DISH Network ViP 211 DTV Receiver
Hdmi inputs does not show a picture. The inputs just stop working.
I'm having the same problem. The projector stopped recognizing any input over either of the two HDMI inputs. The JVC RX-D411S receiver was working fine up until I used the VGA input with a computer and since that time, HDMI has not worked (despite working fine before). I tested two HDMI cables into each of the two ports but nothing! All other inputs work fine.
Jun 28, 2010 | Panasonic PT-AX200U Projector
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
51F510 Input settings for HDMI
Okey,
Connect the hdmi, into the HDMI 1. that is automatically input one. Connect the 2nd device on Input 2, thats next to input 1 and hdmi, leave the input 1 empty, as the hdmi is connected to that.
3rd device into input 3
4th device into input 4.
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
Electro Med Services...
