Question about HTC Cell Phones
Turn off demo
It's eazy open call keypad > press *#*#336666#*#* and choose reset data
Hi, just bought a Whirpool front load model wfw75hefw. Looks like it is stuck on demo mode. Anybody knows how to turn off the demo mode. The dryer was on demo mode and I was able to turn off the demo mode,...
1. Press SETTINGS/CLOCK until "DEMO MODE" is displayed.
2. The current setting will be displayed.
3. Press the "1" keypad to adjust the setting.
4. Press START or CANCEL to exit and display the time of day.
This should put you in normal operating mode.
Apr 08, 2018 | Washing Machines
My whirlpool oven turns itself on and off without me touching it have had this problem before and was told it was in demo mode but don't know how to turn it off
I am not sure this is your issue ... but from the Whirlpool web site .. to turn demo mode off: Possible Solutions
The control has been placed in demonstration mode
IMPORTANT: This feature is intended for use on the sales floor with 120 V power connection and permits the control features to be demonstrated without the oven turning on. If this feature is activated, the oven will not work.
Reset power to the product:
There may be a problem with the User Interface/Keypad, or the associated wiring.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Jan 09, 2018 | Whirlpool Microwave Ovens
My oven AZKM755 is locked in demo mode, how do I get it off demo pls.
To turn off Demo Mode:
1. Press SETTINGS 12 times. "Demo Mode" and "ON. Press (1) to OFF" will appear in the display text area.
2. Press the "1" keypad to change the Demonstration Mode setting to Off.
3. "OFF Selected" will scroll in the text area. Demo Mode has been turned Off.
If unable to access the DEMO setting, contact Whirlpool at: https://www.whirlpool.com/services/contact-us.html
Dec 23, 2017 | In Microwave Ovens
How to turn Mode Demo . Off on my Kitchenaid Walloven
Nov 11, 2016 | Car Audio & Video
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
May 01, 2015 | Korg M50 61-Key Music Workstation Keyboard...
My Huawei h881c wouldn't open my apps and I restarted it and then it keeps turning off and on and It never makes it to my home screen. can anyone help?
I think the only way to fix it is to do a hard / factory reset.
Do the following:
To do a factory reset on the phone, it means that everything on the phone will be removed such as Files, Phone books and others. Here is how to reset the phone. Take the battery out for 1 minute and insert it again. Press and hold the Power button and Volume key Up at the same time and wait until it vibrates. Once the Huawei logo appears, release the Power button while continue holding the Volume key Up and wait for the Android logo to access the blue menu to reset it. Select data wipe/factory reset to delete all user data. Click reboot system now. After the reboot, it should open the phone and you should be good to go.
or check it here step by stp:
First method: 1. First, turn off the phone by using the Power button.
2. Press and hold Volume Up and Power key for a couple of seconds.
3.When you see an android logo release held keys.
4. Press Volume Down to choose "wipe data/factory reset", and then push the Power button to confirm.
5. Select "Yes--delete all user data". Use Volume buttons to scroll and Power to select.
6. To restart the tablet, select "reboot system now".
7. Success! The hard reset is done!
Hope this helps
Second Method:
1. Press the Power button, until your device is on
25491118-3xkfgiy5rrp52d04jqz0avrs-4-10.jpg 2. Then from the home screen open Menu and choose Settings
3. After that select Privacy and tap Factory data reset.
4. Choose Reset device and select Erase everything to begin hard reset operation.
WARNING !
Hard Reset will erase all of your data
All described operations you are doing at your own risk.
Feb 27, 2015 | Huawei Cell Phones
Hard rest nokia 210
To hard reset nokia 210 follow the steps mentioned below:
First Method
1. Turn off the phone by pressing and holding Power button.
2. Open up the dialer by pressing Call key.
3. Tap this code using keypad: "* + 3".
4. Release the buttons that were held, if you see Nokia logo.
5. Confirm Factory reset operation by clicking Call key.
6. The phone will restart now.
Second Method:
1. Switch on the handset.
2. Tap this secret code: *#7370#
3. Press your lock code.
* The default lock code is 12345
4. The phone will reset.
Third Method:
1. Turn on the phone.
2. Press Menu button and go to Settings -> Phone -> Phone management -> Factory Settings -> Delete data and restore.
3. Confirm your decision -> press Yes.
Warning: Performing a hard reset will erase all your data so back up the data before performing a hard reset.
GuruAid.com
Dec 22, 2014 | Nokia Cell Phones
Ce0168 code reset
it is easy to reset it
just follow the steps:
1. Open Settings
2. Scroll down to SD Card and Storage and tap it
3. Tap Factory Data Reset
4. Select Reset Phone
5. Finally Tap Erase Everything.
If you cannot access the settings, you can do a hard reset. It is commonly used when you do not have access to your settings or are locked out of your phone and cannot remember your gmail account. It will delete all data on your phone.
1. Fully turn off your phone. (Remove the battery for 5 seconds to make sure it is off.)
2. Take out the keypad.
3. Press and hold Camera and Power Button at the same time until a Menu appears.
4. Press Volume Down Key, a triangle will appear on the screen. 5. Close the keypad.
6. Tap the screen above the back button.
7. Tap Wipe Data/Factory Reset.
8. Tap ok.
9. Follow the on screen instructions to reboot your phone.
Apr 17, 2014 | Cell Phones
Someome put the lock on when you turn it on and can't get in, it has the time and 9 dots how do I get past this
You will need to do a factory reset:
- Power off machine.
- Hold down + first and then POWER for about 10 seconds, release both buttons once Kurio screen loads .
- When you get the open Android picture, press + to enter menu, use - to move down to "wipe data / factory reset" and press POWER again to choose.
- Next press - to choose "YES" and press POWER to start reset.
- Check for yellow text Formatting /data, formatting cache, Data wipe complete.
- Choose reboot system now and press POWER to complete process.
Oct 21, 2013 | Techno Source Kurio Kids Tablet With...
I want to restart my phone to its factory settings but i can not because i forgot the lock code of my cellphone. is there anyway or any applications i might use to remove the lock code? thanks.
Unfortunately the original password will be needed to restart any security locked cell phone to it's factory settings. I suggest you speak with a customer service representative at your nearest service provider location to fix this issue.
May 03, 2011 | Cell Phones
Cell Phones Logo
44 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
