Question about Pulsar Watches
Pulsar watch vx42-x244 need band pin
I need the pins that hold the band onto the watch
  • 40 Answers
SOURCE: The Pin which holds the watch band in place keeps coming out
you should be able to contact timex and order the pins directly
Posted on Apr 04, 2007
escapement
  • 2334 Answers
SOURCE: need to switch bands and cant remove pins
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 28, 2009
escapement
  • 2334 Answers
SOURCE: How do I get the pins out of the titanium band for Casio PAW1500T
Job done!
Posted on Jul 09, 2009
  • 110 Answers
SOURCE: pin fell out of my fossil watch stainless band.
Stainless steel pins are readlily available to fit most any watch. You should be able to take it to a watch repairmens's shop and have them put it in.
Posted on Oct 31, 2009
  • 103 Answers
SOURCE: Skagen watch band pins I've remove/changed spring
they are very tough they have more pressure on them than most spring pins also on your watch they are tucked into the leather very well. the best way is with a spring tool apply quite a bit of pressure. a normal watch band will not fit this watch. it will only take skagen replacement bands.
http://www.skagen.com/service/home.fx
Posted on Aug 04, 2010
How do you remove links from a casio watch strap S-1183DV on watch WV-59DU ?
You will need to hold the watch firmly in your hand, with the side pointing up. Make sure that you can grip it firmly. If you have trouble holding onto the watch, place it on a stable surface. Make sure that the side is facing toward the ceiling and locate a connecting pin. There will be a connecting pin on each link of the watch band. Select a link, and hold the eyeleteer over the connecting pin for that link. Carefully place the eyeleteer onto the connecting pin. Push gently but firmly until the connecting pin slides partially out the other side. Occasionally, the pin will be difficult to push through the slot. If this is the case, gently tap it though with a standard hammer. Using a pair of pliers, pull on the connecting pin carefully until it slides out. Keep a firm grip on the watch band so that the links do not come apart before you are ready for them to. Separate the Casio watch band. Repeat this process with additional links until the watch band is as small as you would like it to be. Reconnect the band by tapping or pushing a connecting pin into the band where it is disconnected.
Aug 06, 2011 | Casio Watches
How do i take a link out of my stella watch?
mcdevito75 here, Genearlly removeing the bands links are more common with Mens watches but some womans watches also have this option, the links are held together with pins which require a link pin remover tool so these pins don"t get bent. Best Bet is to look for a small watch repair shop in your araea and have them remove a link or two, also hold onto these removed links in case you need them again.
Feb 11, 2011 | Fossil Stella Topring Watch
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
    mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
    Jul 21, 2010 | Seiko SGF204 Wrist Watch
    I have a geneva watch with a large stainless steel band and can't seem to get the pins to release can u help
    Are you sure they are cotter pins? Sometimes they can be mistaken for screws and vice/versa. If they are cotter pins then you need to have a small "punch" tool and a hammer to tap it out. Be careful though because if its a different kind of pressure pin there can be tiny sleeves that put the pressure onto the band to hold it in place! Might want to take it to a reputable watch repair shop to save you the time and possible frustration of attempting an adjustment yourself!
    Jan 14, 2010 | Relic 0504648FA
    Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
    Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
    To shorten the band you have to:
    Extract the pins.
    Take link(s) off.
    Join the rest of band together and drive pins back.
    Jan 01, 2009 | Fossil JR8096 Wrist Watch
    I need to remove 2 links on my pulsar analogue watch.
    You have to drive out the pins from bracelet.
    Split end of the pin must come out first.
    Use blunt steel needle as a driving pin and a small hammer.
    Dec 14, 2008 | Watches
    Kenneth Cole Reaction band
    Call 7298600 x 272 ask for a free pin for model rk 5033
    Aug 27, 2007 | Kenneth Cole RK5034 REACTION
    Watches Logo
    Top Pulsar Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    lessaleadr
    Level 1 Expert
    Are you a Pulsar Watch Expert? Answer questions, earn points and help others
