Question about Rheem Heating & Cooling
Rheem furnice rgaa-0800
Blower runs all the time
    Top Expert:
  • Rheem Master
  • 4,262 Answers
Fan should be on auto
Posted on Sep 16, 2017
3 Suggested Answers
  • 308 Answers
SOURCE: how to wire oil furnice protector relay
3 Wire protectorelay
Black - Power in; White - all neutrals; Orange - Motor and igniter.
4 Wire - Igniter goes to Blue, all else the same
5 or more - Same as 4 wire and
Red - Always "hot"
Violet - Oil delay valve
Pink - Nozzle line heater
Hope this helps
Posted on Nov 19, 2009
heatman101
  • 43501 Answers
SOURCE: Rheem model RGAA-125A .Air conditioner
The heat relay on the main control board is bad...
You will have to replace the control board...
heatman101
Posted on Sep 28, 2010
How do i prime the water trap on a rheem classic 90
This trap will fill itself up when the furnace runs for the first time. It does not need to be primed to make it work. If you have the drain end above another p trapped drain.
Oct 28, 2014 | Rheem Classic Series 90%...
Rheem rgua-080c blower motor not blowing strong
just asking, Is the direction of rotation correct?Or is fresh air open? Fan cage on tight?Is the fan getting the power it needsto reach and maintain proper RPM (SPEED). chk the fan switch. Some have resisters incorated to control speedilica
_
Jul 18, 2014 | Ruud Rheem Squirrel Cage Blower Wheel...
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
20 year old Rheem 90 plus 120k btu furnace blower runs contantly. Furnace and AC work fine (start and stop according to thermostat setting). What is problem? How fix?
Check to see if your unit has a heat sequencer. This is usually the problem with most furnaces. If it is bad, it will make the fan blower run all of the time. If you are not a electrican, you may want to get a electricin to look at it.
Dec 01, 2010 | Heating & Cooling
Rheem model RGAA-125A .Air conditioner works. When I put on heat fan doesn't blow
heatman101
Sep 26, 2010 | Heating & Cooling
How to wire oil furnice protector relay
Red - Always "hot"
Hope this helps
Nov 19, 2009 | Honeywell Electronic Programmable...
Tapan furnice not turning on, The furnice start and the lighter turn on the small fan is running and after about half a minute the first eye turn on for a second and then everything stop
Check to make sure the gas valve is on.
If so it is most likely the heaqt sensor that proves the ignitor is on. Replace the sensor.
Next time post your model number, answer will be more precise.
Oct 10, 2009 | Heating & Cooling
My Rheem central A/C blower motor cycles on & off
Depending on age of Rheem they have a time delay relay. May be causing the problem. The time delay operates the fan. Try turning fan to continuous and see if it stays on.
Jun 07, 2009 | Heating & Cooling
Rheem furnaace blower stays on
On a furnace the fan is controlled by a computer and a sensor ot a oldstyle fan thermostat. Basically it waits till the furnace heats up a little and then turns it on and after it shuts off it will run till the thermostat cools back down may take a few mins. In cool mode the thermostat controls the fan so it shuts down immediatly. This is why the thermostat asks you if its electric or gas heat. Should have a switch somewhere for this.
Nov 19, 2007 | Heating & Cooling
Heating & Cooling Logo
66 people viewed this question
Top Rheem Heating & Cooling Experts
jeff5may32
Lawrence Oravetz
Steve
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
