Question about Vacuums
Just purchased a new Shark Model NV50126. Unit works well but sets off multiple smoke alarms. Has anyone else had this problem?
Changed smoke alarm batteries - Same problem. Called Shark Support and they say they the problem has never been reported.
SOURCE: Adapter
Go to www.sharkcompany.com but it costs $12.00
My dog chewed mine up!
Posted on Mar 26, 2009
gripfitter
  • 557 Answers
SOURCE: I need to purchase a new adapter for a Shark Cordless Sweeper
what you need is a 7.5 volt DC 150mA charger. If you check on some sites like ebay you may locate one. Another option is you may be able to go to an electronic repair shop and they might make one up for you. You nedd to bring them the sweeper so they know what connector needs to on it. A 7.5 volt is not expensive or uncomon and barrel plugs are cheap also.
Posted on Sep 27, 2009
Testimonial: "Thank you very much, your solution was quite helpful."
heatman101
  • 43501 Answers
SOURCE: smoke alarm keeps chirping.
The sensor inside can go bad and that is not repairable...
you may need to replace the smoke alarm..
heatman101
Posted on Sep 06, 2010
ginko
  • 19396 Answers
SOURCE: My hard-wired smoke alarm a
Hi.
To replace or install the batteries, you must first remove the alarm from the trim ring, rotating the alarm (see pic).
After alarm has been removed, you can open the battery door and install or replace the battery. Battery installation instructions are also often provided on the inside of the battery door.
Depending on Lifesaver model, when reinstalling the battery, you may need press the battery reminder finger down into the battery compartment and replace the battery (see pic).
Screw back the alarm to the base to complete the job. In some case, if the alarm is still chirping you need to press the test button to reset.
Posted on Oct 31, 2010
woobie dog
  • 1273 Answers
SOURCE: i need a manual for
Here you are:
http://www.kidde.com/utcfs/ws-384/Assets/1275H_440381en.pdf
Best regards, --W/D--
Posted on Feb 05, 2011
I need ausers anual forthe shark vac steam unit
Hello, this is Ava with Think Crucial.
In order to get the manual for your Shark vacuum model, you would need to find the model number of your Shark vacuum. The Model Number is displayed on the product's rating label on the bottom or backside of the unit. Then you may visit this link to find the exact manual of your Shark unit.
Shark Product Manuals
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 14, 2016 | Shark Vacuums
How to replace power cord on a nv50126 can't seem to get it apart
A lot of times company with use torx screws and they hide them you have to disable the rear housing. Make sure you watch how you take it apart because you will need to do the revised to reassemble it. Also make sure you put a cord whip on the housing were the cord go' s in
Good luck and just take your time
Apr 27, 2016 | Shark Navigator Bagless Upright Vacuum
How do I register my Shark vacuum Model # NV 752 31
usually have to go to their website to register products . that information will be with the unit when purchased new .
Jan 17, 2016 | Shark Rotator Professional Lift-Away...
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Lanson smoke alarm model LANSD240B S/N 139606 Alarm alert beeping. Replaced battery, tried 2 new battries, still beeps. No smoke or fumes found.
try this, remove the unit and take out the battery you will see 4 small rubber plugs in the back.
remove these and take out the 4 screws, you will find a lot of dust and insects in there, gently blow out with compressed air and the sensor as well.
I did 2 problem ones in my house and now they are working fine
Feb 18, 2011 | Vacuums
HA-871? I'm not sure if anyone can help with this, but I've got a **** Smith brand HA-871 alarm system which I haven't used in years. When trying to get it working, not only have I forgotten the code...
Incase you are still interested you set the code with the four jumpers inside the unit.
1st digit is the brown wire
2nd digit is red wire
3rd digit is orange
4th digit is yellow
Oct 11, 2010 | Vacuums
Smoke alarm keeps chirping. put in new battery and continues
heatman101
Sep 05, 2010 | Vacuums
I have a Uni-com wireless doorbell, model 55075/SC352R. I would like instructions as I'm not finding it easy to reset things and have inadvertantly set the alarm and don't know how to turn it off!
With the display in normal mode showing the time, date and temperature and with the double dots flashing each second, press the MODE button. The first press will give you the option for setting 12 or 24 hours on the time display. The second press should bring up the setting for the alarm time. Press the SET button once and it flashes the hour for the alarm. Press it again and the minutes for the alarm will show. Pressing the SET button a third time lets you set the number for each musical tone choices for the alarm. A fourth press will ' set' the alarm so the alarm time will show, plus the number representing the ring tone you selected below the alarm time. Normally what you would do next is press MODE again 3 times to return to the ordinary time display. But if you want the alarm off, instead of doing this, press SET a fifth time and this will set the alarm time to 'off' and the display for the alarm will show '-:--' now press MODE 3 times or until you see the ordinary time display with the double dots flashing. You can check the alarm is off by pressing the ALARM button - it should still show '-:--'. The ALARM button is only for showing the alarm time which has been set, not for actually doing the setting. A quicker way, starting from the normal display with the seconds flashing on the time, is to just press the ALARM button once, then press SET 5 times then MODE 3 times.
Aug 27, 2010 | Vacuums
Our carbon monoxide dectector model CO910, bought several years ago (10+) beeps every 30 seconds with an "err" message. All windows where it is are open. No one is feeling ill. Is it just an error on...
CO2 and Smoke detectors have an internal sensor that has a design life of 5 years from the date of manufacture. After the 5 years you start getting false alarms due to the sensor itself exceeding its average life span. On the combination CO2 and Smoke deterctors you will often see a manufacture date or a replace by date inside the cover on the main board.
On AC powered models such as this one you will just get the error when the sensor fails. If you got the full 5+ years out of your CO2 sensor then you should be happy that it served a full life expectancy.
Some Wiki data on CO2 detectors:
http://en.wikipedia.org/wiki/Carbon_monoxide_detector
This paragragh appears under installation
The gas sensors in CO alarms have a limited and indeterminable life span, typically two to five years. The test button on a CO alarm only tests the battery and circuitry not the sensor. CO alarms should be tested with an external source of calibrated test gas, as recommended by the latest version of NFPA 720. Alarms over five years old should be replaced but they should be checked on installation and at least annually during the manufacturers warranty period.
Thanks for choosing FixYa.
Kelly
Aug 02, 2010 | Vacuums
Vacuums Logo
147 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
