Question about John Deere Garden
JD x585 temperature guage
Temperature guage says running hot all the time
SOURCE: Temperature guage shows hot
you need to make sure you have enough coolant in the radiator and oil in the car its better to take it in before you do some damage even that the engine is not hot its heating up inside very fast
Posted on Dec 31, 2008
SOURCE: 1994 Chevy Silverado temperature guage shows hot
Flushing the radiator, replacing the radiator cap, adding new coolant, replacing the sensors and a new thermostat solved the problem. Probably didn't need to do all of these things - but since we just purchased the truck, and given the fact that is probably hadn't been done in a while, we chose to do all of these things (which really didn't cost a whole lot), it's running like a charm now.
Posted on Jun 03, 2009
  • 126 Answers
SOURCE: I have a 98 cavalier rs, the guage lights flash,
1 Inspect Fan Clutch Faulty Fan Clutch. 2 Inspect Air Dam / VALANCEat Broken or Missing Air Dam. 3 Inspect Water Pump Worn, Cracked or Leaking Water Pump.u have to have the check engine light reset
Posted on Sep 02, 2009
  • 608 Answers
SOURCE: in the 95 4runner, what should the temperature
Which engine does your forerunner have? They are not known for overheating, so you may have a problem in your cooling system. Is the system losing water? The first thing to do is get a pressure test of the cooling system done. At the same time ask them to test the thermostat. If all ok, Have the engine and radiator reverse flushed, and add corrosion inhibitor. Should be ok after this is done.
Posted on Mar 31, 2010
  • 14585 Answers
SOURCE: 1988 BMW 318i temperature guage
It could be the impellor wearing out on the water pump, though I have not heard of this issue in your make of car, I have seen it first hand in other makes. The thermostat may not be opening up all the way, flow restriction,. The coolant temperture sensor could be going out, and the gauge in the dash could be going out. You could have flow restrictions else where in the engine. Have you ever had the engine flushed? these are the things that I can think of that would make your engine run hotter than normal.
Posted on Nov 18, 2010
Temperature guage goes to full hot when running . Replaced sender in left head [single pole ] When you turn key on needle moves toward cold . When engine runs as soon as it starts to heat up guage goes...
Than probably the reading of the temperature is correct or the sensor is too sensitive. So, first things that comes up to mind is if it is the correct sensor you use, or is it damaged.
If correct sensor and not too sensitive, it means the reading is correct. Which leads us to look for the problem causing this drastic raise of temperature..
Oct 09, 2013 | Ford 1953 Crestliner Sunliner Red 1:18...
91 acura integra overheats but temperature gauges show normal operating temperature whats they problem?
Check that the fans are working when it is hot, If the fans are working the thermostat is probally stuck shut, As for the guage the temp sensor is shot,
Nov 29, 2012 | 1991 Acura Integra Hatchback
Check engine light comes on and then the temperature gauge goes up to hot
Mine did it too.... The problem is the Engine Power Relay.
The Engine Power Relay is in the relay box in the engine compartment. Aftermarket relay is cheap, but the original Ssangyong part will last many years longer.
Hope this helps.
Jun 02, 2012 | SsangYong Rexton Cars & Trucks
Tamp gauge is over heating when the car is in idle but not when driving all the time. The radiator fan switch on the water outlet has been changed, new thermostat, all liquids are full and not leaking. The...
Since you just replaced the thermostat and it still over heats there is a good chance you have air in your cooling system. You can find step buy step instructions on my tip and how to page. Feel free to take a look.
Sep 17, 2011 | 1993 Honda Accord
1988 BMW 318i temperature guage flickers between normal temp. through to max temp. Most of the time the guage is 3/4 to Hot. Main fan seems a little loose when hot - not tightening up. Coolant level OK no...
Nov 18, 2010 | 1997 BMW 318
Sep 01, 2009 | 1997 Chevrolet Cavalier
Jun 02, 2009 | 1994 Chevrolet Silverado 2500
Dec 31, 2008 | 1995 Jeep Wrangler
GUAGE SHOWS HOT
is it ever low in coolant? i agree with emissionwiz sounds like your getting airpockets do you have heat when this starts?
Nov 09, 2008 | 2002 Chevrolet Avalanche
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
