Question about Garmin nuvi® 200 Car GPS Receiver
Garmin 200 nuvi will not take a charge , the plug in port seems loose .can the unit be split in half so that I can push port up into  placeIs there a repair manual ?   Thanks
  • bhhemlock May 08, 2009
    Tim, Does this unit split in half so I can inspect for  the problem also are the jacks available from a local source I am hoping to make repairs myself because I will be going on a trip in a week and wouldn't have time to send in for repair  I live near  Saginaw Michigan  Thanks Bob
    the jack on garmin 200 nuvi is loose and unit will not take a charge I would like to make repair myself does this unit split in half so I can inspect the problem and re solder if necessary also where are parts available I live in Saginaw Michigan area , please explain how unit breaks apart for repair Thanks Bob
  • 413 Answers
I guarantee you i have fix for this
visit link: http://www8.garmin.com/manuals/1512_SetupandGo!.pdf
Posted on May 08, 2009
  • 234 Answers
It sounds like the jack needs to be replaced on the unit. This is a very common problem with plugs on portable devices. It is possible that the solder connection is also bad and the jack is OK. It is usually best to replace the jack while you have the unit apart.
You should be able to take the unit apart to repair the problem.
There aren't any repair manuals available to do this.
You can also have an electronics repair shop fix it or send it to the manufacturer for service.
If you need more help, post a comment and I will get back to you.
Thanks,
Tim
Garmin nuvi 2555lm battery want charge
A common problem with these units are loose/broken connections on the rear USB port. There are 5 pins on this port. If the power pins are loose/broken, the unit will not be able to charge the battery. The unit will not turn on because the battery is dead. Even if you plug in the charger, there battery will not charge.
The unit will not charge the battery if it won't turn on.
While you could have a bad battery, the Nuvi 25xx series is not that old and the date code on the battery is probably from 2010 or later.
If you plug in the charger, the green battery status indicator should go away or you should see a lightning bolt appear over the battery status indicator . If you don't see a change to the battery status indicator when you plug in the charger, then this confirms that the rear USB port is broken and not applying a charge to the battery.
More information can be found here:
http://www.sharc.net/gps_battery_repair.htm
http://www.sharc.net/gps_charger_repair.htm
Mar 25, 2013 | Garmin nuvi GPS
My Nuvi 200 will not charge and the USB port
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
Mar 16, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 not charging
I also have a Nuvi 200 that didn't charge. The problem is the charging port disconnected from the circuit board. You can disassemble the unit and reconnect the charging port but it takes a small torques wrench and a small screw driver. You will also need a soldering iron preferably with a fine tip and a very steady hand. Good luck.
Sep 24, 2009 | Garmin nuvi 200W GPS Receiver
Two year old #200 unit. Plug seems to come loose
yikes! unfortunatly it sounds like you will have to send that back into garmin for repairs. for loose parts inside they are the only people who are authorized to repair it. Unless you know someone who is good repairing electronics
garmins website will give you a flat rate repair on what it costs to fix it.
Aug 14, 2009 | Garmin nuvi 200W GPS Receiver
Is m Garmin nuvi 200 GPS charging
Merritt, Your Garmin Nuvi does not have a charging indicator similar to say your Cell ph. Simply a battery charge indicator scale. Normal full charge time is approximately 3 to 4 hr. If you looking to ensure your unit is in fact charging Plug in & then remove the connection, Your unit will pop-up a screen to request if you wish to remain on battery power. I hope this helps you.
Mar 09, 2009 | Garmin nuvi 200W GPS
The jack in the back of my nuvi 200 pushes in when
actually that component is soldered on the internal board and now its got moved from its position and the soldering has vcome loose.just get that component again soldered on the board to make it properly charge.
Mar 02, 2009 | GPS
Garmin gps won't charge while driving
If the Nuvi won't charge when connected to charge but charges on USB, then the charger port is faulty.
If the Nuvin does not charge at all , then the battery must be replaced.
Dec 27, 2008 | Garmin Nuvi 350 Car GPS Receiver
Just got a nuvi 200 and can't even charge it .I have an adapter for my cell phone but see no place on nuvi to plug it in. GuessI should stick to road map !?
The charging port is a mini-USB socket located on the rear of the unit. You should have received a car charger with the unit if it was new.
- Jim
Nov 23, 2008 | Garmin GPS
My Garmin Nuvi 200 wont turn back on
Our Garmin didn't turn on. We unplugged it, pushed the reset button on the bottom and then plugged it in again and it WORKED
Aug 02, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi® 200 Car GPS Receiver Logo
127 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
