Question about Motorola Radio Communications
My 2 way motorola (k7gt8500) walkie talkies are on the same channel but whenever i try to talk into them they dont let me
Whenever i press the PTT button it beeps and goes back the main screen
  • Motorola Master
  • 1,654 Answers
You have a bad or poorly charged battery
Posted on Dec 17, 2015
2 Suggested Answers
Neto
  • 123 Answers
SOURCE: Motorola Talkabout T5100
I think you have to remove the courtesy beep option from radio, this is also call Roger beep.
Posted on Dec 12, 2006
I have a set of Motorola T5720 walkie Talkies. I cannot determine if one of them is not receiving or the other is not transmitting.
One radio works properly, the other can receive. I assume there are more than two by the question. Check and then rotate you batteries, mark on the working unit battery that it is GOOD. Transmit takes a great deal more power than receiving. Batteries, even un-used only last 18-24 months typically. If no joy, then check your programming but I think that is unlikely. It really sounds like a power/battery issue.
Aug 28, 2016 | Motorola Talkabout T5720 (7 Channels)...
Can I turn off the beep on the cxt195?
You mean the "roger beep"? You can try the steps below from this site>>http://science.opposingviews.com/turn-roger-beep-off-motorola-walkie-talkie-10001.html
Step 1
Turn the Motorola Talkabout two-way radio on by pressing the "Power" button.
Step 2
Hold down the "Menu" button for several seconds until an icon appears on the screen. "On/Off" begins to flash on the screen.
Step 3
Press the "Minus" button to turn the "Roger" beep off. If you want to turn it back on, press the "Plus" button.
Step 4
Tap the "PTT" button to save the change. You may also press "Menu" to save the change and completely exit Menu mode
Hope it helps...
Dec 03, 2014 | Radio Communications
How to use radio in my walkie talkie
press & hold "mode" then use the channel up & down button until you hear it, depress the PTT to return to normal
Apr 19, 2014 | Cobra Microtalk 100 FRS Walkie Talkie...
I have a Motorola Talkabout from 1998 that has a talk button, a monitor button, and a power button. Whenever I press the talk button it just says the channel....but when I talk through my other walkie...
It seems a small hardware-problem, like a button is sticking, making a continues connection. If you are comfortable in hardware-modifications, try to open the casing of the malfunctioning walkie talkie. Do this carefully, not to damage it further.
When opened, check the 3 buttons to see any damage, or undesired connections (caused by extensive use or plain dirt).
Oct 14, 2013 | Radio Communications
Radio keeps beeping when I turn it on? I confirmed its not because of a low battery but something else.
A few thoughts:
If it is a long continuous beep this can be an indication of having the channel select set to a channel which is not programmed.
If it is a beep that only occurs when you press the PTT button, similar to the low battery beep, it could be a battery, battery contact, or internal battery contact issue. Clean battery contacts between radio and battery, as well as external contacts, with a pencil eraser to assure a good connection.
If it is a beep that occurs periodically when pressing the PTT button, it is possible your radio is programmed with busy-channel-lock-out (talk prohibit tone), which would not allow you to transmit on a frequency which is already in use.
Best regards.
Oct 11, 2013 | Motorola Mag One BPR40 Two Way Radio
I ptt and it immediatley 'roger beeps'
Beeping when you press the PTT button usually indicates a bad or weak battery. Check your batteries and charger. Clean contacts with a pencil eraser.
If you feel this is not the problem, then you have a radio problem. These radios are non-repairable, as parts and schematics were never released for them.
Best regards.
Dec 12, 2012 | Motorola Talkabout® T9500 Two Way Radio
When I press PTT the walkie talkie turns off
Dead, shorted, not fully charged, bad battery connection, or bad battery.
Jun 15, 2012 | Radio Communications
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Nov 09, 2010 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
