Question about VeriFone Nurit 8000 GPRS Wireless credit card terminal
What is waiting register - VeriFone Nurit 8000 GPRS Wireless credit card terminal
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
TIP: IF REGISTRATION FAILED, REPEAT THE ABOVE PROCEDURE.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
NEED TO DEREGISTER LOST HANDSET
The "END" and "#" key combination can be used for several purposes:
1) If wanting to use an ALREADY REGISTERED HANDSET on an alternate base, and if if the INITIAL BASE isn't available to deregister the handset:
1a) Press "END" + "#" until it for 5+ seconds (wait for it to beep)
1b) Choose the "Base Unavailable" option
1c) That'll deregister the CURRENT HANDSET so that it can be re-registered on ANY base.
2) If a BASE has a handset registered to it which you no longer want registered but the registered handset is missing or broken:
2a) Grab another WORKING handset which is properly REGISTERED to the BASE in question
2b) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
2c) Choose the "Deregister HS" menu option
2d) Pick the REGISTERED HANDSET # to de-register. (Every other registered handset EXCEPT THE ONE YOU'RE ON will appear in the list!)
May 08, 2009 | Uniden TRU8866 Cordless Phone
Side kick
Try reseting your phones settings and if that doesnt work then t-mobile should fix the problem  hope this was useful :)
Nov 10, 2008 | T-Mobile Sidekick
"Please wait" (rebooted, then) "searcing for signal"
Sounds like the base station and console are no longer registered to each other. Press the menu key, then admin setup then registration. Follow the prompts to register the base with the console.
Oct 01, 2008 | Polycom SoundStation 2W (2200-07800-001)...
BT XD5500 manual
BT Freelance XD 5500
Resetting the base & handset/s on a BT Freelance XD5500:
Hold the Find button on the base unit until you get a double beep then
tap the Find button 7 times.
On the handset:
remove a battery
hold the menu key and refit the battery
screen says SW VERSION
press up arrow key until screen shows REGISTER CLEAR
press menu
press menu again and wait for OK to appear
remove a battery and refit
Registering the XD5500 handset.
Then register the handset to the base as follows:
Hold Find button on base unit until you get two beeps
On handset:
Press menu
Scroll to register
Press menu
Scroll to Register Base
Press menu
Press 1
Wait
When it says PIN ? Enter 0 0 0 0 (four zeros) and press menu.
Note:
If you have more than one handset then repeat registering the handset to the base for each subsequent handset/phone.
If this procedure fails to solve the issue, then you have a unit with a
fault and if it is less than a year since purchase the retailer should
change it for you.
Aug 03, 2008 | Lands Phones
TRYING TO REGISTER NEW GRILL AT WWW.GRILLREGISTRATION.COM RE-THE MANUAL DOES NOT COME UP TO ANY REGISTER. HOMOPHONE IS WHAT COMES UP. PLEASE ADVISE. ID2THFAIRY1@CABLEONE.NET THANK YOU
I am trying to go to www.charbroil.com/register for 30 min now and I always get error messages. I bought the grill yesterday and want to register it. Help, please. Gisela
Jun 24, 2008 | Kitchen Ranges
Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Jun 22, 2008 | Panasonic KX-TG2356 Cordless Phone
VeriFone Nurit 8000 GPRS Wireless credit card terminal Logo
35 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
