Question about Garden
I have a problem with a 46" twin 18 automatic
I have a problem with a 46'' twin 18 automatic drive mower. usely I have to pull up on the drive petal to get it to go,also when it gets hot it slows down and stops. Would there be something wrong with tranmission ?? It doesn't take but a slight movement to start moving again.
  • 86 Answers
Sounds like could be drive belt or spring !
Posted on May 09, 2009
I need to route the belt on my Husqvarna YTH22-46 riding mower.
Please follow the link to the owner's manual, the belt routing is shown on page 18 of the pdf file, scroll through the pages at the top to get to page 18.
Husqvarna OWNER YTH22V46 Owner Manual Service And Adjustments
Aug 09, 2016 | Husqvarna Garden
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
Can I swap the motor from a Husqvarna YTH 180 and put it in a Husqvarna YTH 1848 HP?
The 1848 uses an 18 HP Twin cylinder engine. Mine is a Kawasaki but a similar 18 - 21 HP Kholer will also work. Can't see a problem
Nov 06, 2014 | Husqvarna Garden
Need diagram for belt instalation for murray 46" cut
Select Index Numbers here:
2 Asm, Jshaft Housing Head W
3 Q2 Pulley , 46"
4 Shaft, Splined Jacks
6 Nut, Pulley
7 Hub, Blade Adaptor
8 Q4 Blade 46" Mulcher
9 Washer, Bellevile(ard
10 Washer Hardened (ard
11 Nut Hex (ards)
12 Screw, 3/8, 16X1.25
24 Rod Belt Guide
25 Belt Cross Drive Ja
26 Belt Primary 46" J
34 Bracket Cover
35 Bracket, Pulley Cover
36 Qx Lburg# 094605E700 -INACTIVE-
37 Use Lburg# 093349 Zi -INACTIVE-
38 5/16, 18 Hexwdfllk Wh
39 Screw, 5/16, 18X.75HH
40 Cover, Pulley Right
41 Screw, 10, 16 .190X.62
72 711327
72-1 Wheel, Gauge
72-2 Bolt, .500X3.275HHSH3
72-3 Spacer, Slev .515X1.
72-4 Nut, 3/8, 16 Hxctrlkj
72-5 Qxcolor Code Require -INACTIVE-
79 Pin Detent Ring (DP5
80 Asm, Mulcher Plug 46
81 Bolt Carriage (ards
82 Nut, Wing (ards)
89 Zerk, Grease Fitting
Apr 21, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
What size belt for powr kraft 18/42 industrial commercial twin cylinder automatic hyrostatic dive .need deck belt.
My mower is 18/42 power kraft, limited addition, hydrostatic. I need to replace deck belt because deck belt was bitten by mouse. May I know belt routing and how to replce it. Thank you.
Jan 28, 2012 | Garden
I have no spark on the road side of my 1997 18 horse power V-Twin Kawasaki engine in my craftsman mower.
not quite sure if you have spark at all or just on one cyl,either way it is unlikely that your main coil is bad but look for a wire on that side of the mower that may be shorted to ground and if it is it may have sorted out your trigger coil. It is a very small electronic box about 5/16 thick by 1"x 11/2", light in color. A quote I was given by a kawasaki expert was that nine and a hlf times of ten it is the trigger coil.spendy little buggers too.
Sep 23, 2009 | Garden
Need diagram to replace blade belt for 19hp twin turbo cool mower
You have to post the model number from under seat. Not all Craftsman decks are the same. There are 38", 42", 46" w/3 blades, 46" w/ 2 blades, 52", etc.. Better yet, Get the model number under the seat (starts with 917) and go to... http://www.searspartsdirect.com/partsdirect/index.action Then enter the model #, hit search, then scroll down to Browse Subcomponent List and click on Mower Deck. There's your diagram.
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Drive belt diagram
go to sears.com and put in model# for parts look up and they will have it or call 1-800-4my home to get owner manual
Apr 30, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
