Back to:
Tags:
Standard Televisions
Generic problem for all Standard Televisions
Picture fault (by 2 users)
posted by stevemb on Oct 10, 2007
Picture has shrunk width ways, picture edges are jagged with no aerial input blue screen has flyback lines
Comment by stevemb, posted on Oct 10, 2007
Should have said its a sanyo 28" widscreen Model CE28WN5
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by mbice, posted on Nov 25, 2007
I am having problems with my RCA Model F27440. The picture is offset to the left side and i can not see the very left side of the picture is there a way to reset this? I do not know whre to begin because there is no visual setting or manual setting on the back.
Solution #1
Not Rated (0)
chrispurs1
Rank:Guru Guru
Rating: 86%, 312 votes
Hi.
What is picture like if you change screen size to 4-3  is this picture size ok & fault only shows in the wide screen formats.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Picture fault:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
Toshiba TP50F60/61 TV
I just traded an old amp for this tv. It turns on and it...
ESA ET427E 27" TV
need a remote control code for ESA ET427E 27"...
Sony FD Trinitron WEGA KV-32FS120 32" TV
checked strw 5753 and resistance ( r 627 ) burn can't read...
Zenith C27A24T 27" TV
I just bought DTV converter Box for my 27" Zenith...
Philips Magnavox TS3260C 32" TV
It will not go to channel 3 and does not respond to my...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
