Question about Sony Audio Players & Recorders
Sony st-jx301 tuner have to keep memorizing favorite channels when turning it on
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 924 Answers
I guess you mean that it looses the memorized channels when you turn it off? It probably has a backup capacitor that's gone bad.
Posted on Dec 12, 2014
2 Suggested Answers
  • 1212 Answers
SOURCE: I NEED A RIBBON CONNECTOR FOR A SONY SYSTEM MODEL TC-W301,ST-JX301,TA-AX301
You should be able to get the length and conductor count from Digikey, as well as the Berg/Tyco type connectors. They may not match the originals, but they should work fine. Otherwise your best bet is Ebay.
Posted on Oct 31, 2012
WHEN I PLUG INTO ANTENNAE--I GET " NO SIGNAL"---BUT I KNOW THAT THERE IS A SIGNAL BECAUSE I GET A PERFECT PICTURE ON MY SONY COLOR TV? HOW CAN I GET THE OLEVIA TO RECOGNIZE THE ANTENNAE SIGNAL?
You'll need to use the Olevia remote and press the MENU or SETTINGS button. The choose the SETUP or MEMORIZE CHANNELS option. MEMORIZE CHANNELS may be in an ANTENNA screen.
When you memorize channels you'll need to set the option for Antenna or Cable TV then have it memorize channels.
The television will run through each channel looking for signal and memorize those it finds. Sometimes it finds a very weak signal and you'll need to manually remove some.
Oct 04, 2015 | Sony Televison & Video
How to switch from analog to digital
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
Can you please advise which external tv tuner will work for SONY trinitron kv-xf21m80 model? My SONY crt tv tuner is not catching most VHF B/G channels. i sought the services of an authorised service...
If you have a cable box and can set your TV to channel 3 then you should be able to watch cable. If you want to watch over the air broadcasts then you need a digital converter box which you can buy at Best Buy for around 40 dollars. You use the converter box as the tuner and set your TV on channel 3.
http://www.bestbuy.com/site/Coby+-+ATSC+Standard-Definition+Converter+Box/9663904.p?id=1218140711965&skuId=9663904&st=digital%20converter%20box&cp=2&lp=5
Dec 24, 2012 | Televison & Video
Oct 24, 2012 | Sony Audio Players & Recorders
HOW DO YOU GET CHANNELS REPROGRAMED INTO THE TV?
Hello
Auto presetting channels you wish to know I thinks, if so do the following.
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
? When AUTO PRESET CH action is completed, the lowest memorized
channel reappears on the screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH",
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
OK.
Jan 11, 2011 | Emerson EWF2004 20" TV
What buton do press to get the channels?
Hello
To tune the TV either with cable of trerrestrial antena, plug in the cable or terrestrial antena cable to the antenna socket of the TV and do the following.
on the TV screen.
channels.
OK.
Dec 16, 2010 | Emerson EWF2004 20" TV
My Pioneer AVIC-D3 gives a message that says, "CH001 is currently playing" about every minute, even when I am actually on channel 150? How can i get it to quit?
You have memorized a track of "ch001". You can create "memos"/memorize any song you like and the player alerts you when it's playing on another station. If you touch the "memo" button when you are setting up your receiver, like I did, you will get a notification and an alert asking if you want to change to channel 001 because it thinks it's one of your favorites. To stop this, simply press "menu" on top left corner of unit. Go to "Function", touch "memo", and you will see all of the tracks you have memorized. Touch and hold the track you want to delete for 2 seconds. You can also delete all, or turn off alerts.
Jul 08, 2010 | XM Radio (XMP6000)
Y sony direct comparator st s444 es 2 does not hold radio stations. Once power has been turned off for more than a couple hours, memorized radio stations are lost. Thank you
You could try looking for a memory retention capacitor on the circuit board. It will be on the board with coils etc. They sometimes are marked on the board. However they look like squashed electrolytic caps. They have a value of between 0.022 and 0.047UF and a voltage of around 5.5 volts. If you see one like that and it's near an IC then you found the trouble, replacement should stop the loss.
May 15, 2009 | Audio Players & Recorders
How to program pre-sets on a Sony tuner ST-S100L
Tune in the correct station with the big +/- buttons. Then press "memory" then type in a number with the pad (it will do double digits, but normally a single digit is preferable) then press "enter"
Now typing in that number then pressing enter will take you to that station.
Good luck.
Dec 12, 2008 | Sony ST-SA50ES 2 Channels Tuner
Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
