Question about Ricoh Aficio SP C222SF All-In-One Laser Printer
SP C222SF multifunction Printer Problem
Hi i have the SP C222SF multifunction Printer, and when i firt turned it on it remains displying Initializing and nothing happends.
No matter what i do, same thing again.
Please Help
Nico
    Problem Solver:
Dear colleagues,
I have aficio spc 232, when powering on, it stays displaying initialization message and never comes redy.
Please any one can help me to solve this problem.
Many thanks in advance
Boualem
UAE
Posted on Oct 05, 2010
I am also using the SP C222SF printer and am experiencing the same problem with the initializing word on the screen. Did anyone manage to solve the problem? Kindly share it here. Many thanks!
Li
Posted on Nov 10, 2013
SPC222SF IS GIVING ERROR ""PLEASE REBOOT SYSTEM ""
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
Oct 18, 2014 | Ricoh Aficio SP-C222SF Flatbed...
I have a Ricoh sp c222sf multifunction machine. I'm running Windows 7. I loaded a driver for both the printer and the scanner from thier website. All seemed well until I went to scan from the ADF. It...
u got to unscrew the scanner a bit and arange the adf left or right depending your line position. the adf is not positioned perfect on the machine , and at the end it scan the adf back , thath is the line come from on your scanned document
Feb 02, 2011 | Ricoh Aficio SP C222SF All-In-One Laser...
When I try to print something it says the bypass tray is empty, but there is paper in the printer.
Take all the paper out. Turn off the printer, Wait ten minutes. Turn on the printer. Put the paper back in fastidiously.
Regards,
selk
Oct 18, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
RICOH SP C222SF SC300ERROR WHAT IS IT. CAN IT BE
SC300 on a C222SF is a high voltage power error. You could reseating the connectors for the high voltage power supply and the engine board (EGB), but more than likely one of those two boards will need to be replaced.
May 25, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Ricoh SP c222sf is not recognizing that there is paper in Tray 1 or bypass - tried to rest tray 1 and turn on/off, but the display still shows that there is no paper. What else can I try?
There is a paper detect sensor which sits in the frame of the machine above the paper tray. Pull the paper tray out and make sure this sensor didn't get broken or knocked out of place. (If you have a can of compressed air, shoot some into the sensor to get rid of possible paper dust.)
Mar 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Sc300 service call
On the SP C222SF, sc300 is a high voltage output error. More than likely, either the high voltage supply board (HVSB) or engine board (EGB) is bad and needs to be replaced. However, before going that far, you can try turning off and unplugging the machine and reseating the connectors that go to those two boards. Sometimes a loose connector can cause a service code, and fixing the connection can clear the problem up.
Feb 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
With colour output from a Ricoh SP C222SF Aficio I'm getting lines through all colours, from print and photocopy. Do I need to replace toner, or clean something...? Suggestions welcome!
Pull out your toner assys and look at the drums on each the should look clean under this is the belt that transfers all the colors it also should be clean, the last possibility is the fuser these are all maint items. Have you tried to check the maint items? (menu OK machine settings OK Supply info) or Menu OK machine settings OK TB clean.
-Carl, please let me know if this helps.
Jun 14, 2009 | Ricoh Aficio SP C222SF All-In-One Laser...
Ricoh Aficio SP C222SF All-In-One Laser Printer Logo
611 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
