My washine machine stinks! I have run salts
My washine machine stinks! I have run salts through it, bi-carb and vinegar and nothing seems to help. The odour is getting so bad it's going through the whole house and by the morning we're nearly sick! Help! It's a Westinghous lt819s.
Thank you
  • 98 Answers
It sound like its not draining all the way. make sure the outlet hose is sitting about the same height as the washer. also the pump might be cloged with alot of lint hair paper stuff like that. so its not lounding it to drain
Posted on May 08, 2009
Can you remove the drum from lg fuzzy logic WF-T65T1 to get rid of mouldy smell
It is a big job. Why did you use vinegar and bicarbonate of soda? They cancel each other out. The drum is stainless steel, it can't smell. The smell is from mold on the rubber pipes and in particular the door gasket.
Put 2 cups of bleach in the machine and a couple of white towels or a load of white tea towels. Run the hottest wash for the longest time.
After you do a wash, dry the door seal and leave the door open for a couple of hours so everything dries out..
If it persists, get an engineer to replace the door gasket. Then keep it clean and dry.
Dec 18, 2017 | LG Washing Machines
Only make small amount of coffee spits and sputters hard to come out
You need to remove the salt build-up deposits. Run two cups of vinegar through your machine. (Add vinegar instead of water, no coffee or filter). Push start and let the vinegar fill the pot. When done, repeat if you think more scale/deposits will come out. Do a final rinse with water (plain water to rinse the vinegar). Then make coffee.
Sep 04, 2014 | Coffee Makers & Espresso Machines
Heat up taking longer and dosage of coffee smaller
Its going to stink, but run a full tank of straight vinegar through it (without coffee) then run water through it a couple times to rinse the vinegar out (without coffee) Afterwards should be back to normal operation
Feb 28, 2014 | DeLonghi Magnifica Coffee Makers &...
Ariston ar6f105 washin machine not working
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
Aug 18, 2012 | Ariston Technologies Washing Machines
I have a 18month Electrolux 8kg front loader which has mould on the bottom part of the rubber seal. I have always kept the door open after every wash but the mould has set in. I have tried wiping it with...
You will find that wiping it dry, then painting it with thick household bleach and leaving it overnight will have an excellent effect on the staining. The rubber will tolerate the bleach without any problem. If one night doesn't quite cut through the mould, treat again the following night.
Just remember to wash the bleach away thoroughly, so that it doesn't affect any garments in the next wash!
Jul 29, 2011 | Washing Machines
My washing machine smells really musty, have used bi carb soda and bleach it still stinks
you can try a cup of white vinegar running in a hot cycle alone.  if that does not do it or you want another possibility, k-mart and sears sell a product called washer magic and it works fairly well...  try doing this about once ever 2 months or so and it will reduce the oder greatly.
Aug 05, 2010 | Washing Machines
Stink
Run a solution of hot water and vinegar in your tub on a full cycle using the hot and cold use about 1 cup of vinegar. Just stale water that always sits in the bottom of the washer
Jan 13, 2009 | Amana ALW480DA Top Load Washer
Dishwasher not cleaning
The dishwasher salt response is acceptable for Europeans, but U.S. dishwashers do not have a salt dispenser, nor is dishwasher salt sold in U.S. stores. U.S. consumers should descale their dishwasher using Dishwasher Magic, Lemi-Clean, Lime-A-Way, CLR, or vinegar until scale is removed from the machine, then add a rinse aid to the dispenser, which should prevent future problems. For very hard water, regular, periodic descaling treatments should be done. For the vinegar cleaning, place a full cup (8 oz) of vinegar in the top rack of the dishwasher. This way the vinegar is release throughout the wash cycles, performing a more thorough cleaning.
Sep 13, 2007 | Dishwashers
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
