Tried to download the latest version of speeder xp but it wont let me remove a file from my previous version.
SOURCE: video card with 64 mb and pixel shader version 1.1
Easiest way is to right click the desktop> click properties (or Personlise - in Vista)> then the settings tab (or Display Settings in Vista)>then advanced> then the adapter tab > you will then see a list of your graphic card,its memory and bios information.
Let me know what happens.
SOURCE: DIsable touch pad on Inspiron 1501 laptop with XP
In your system you should be using synaptics touchpad driver. First of all look for it under mouse properties in control panel. If its not there then install in from support.dell.com. Under this application you would be having option to disable touchpad when external mouse connected. Try this.
Please rate the comment
SOURCE: dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
SOURCE: drivers for dell inspiron 1501 with windows xp in it
No worries.I can help u with that.This link will give u the compatible drivers for ur system : http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_1501&os=WW1&osl=en&catid=&impid=
Just beside the picture of the laptop in the website,u have the link which will help u installing the drivers in the right sequence.
U can also visit support.dell.com for the same.
SOURCE: Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
