Question about IBM (89P8010) Motherboard
Rev 1.5 video drivers
I need update for win7
Desktop screen went big and will not go back to original settings
There are two possibilities.
1) The resolution has been changed. To fix that do the following.
Instructions are for Win7
  1. Click on "Start" on the bottom left corner.
  2. Control Panel
  3. Under "Appearance and Personalization" select "Adjust screen resolution"
  4. On "Resolution" set the resolution to the highest possible number and see if that works for you. If not keep going down till it is the size you prefer
2) You need to update your video card drivers.
The solution for this is to update your drivers from the video card or desktop manfucturers website.
Oct 08, 2013 | Computers & Internet
MSI K9AGM display
This is a common problem for this board. Don't use the upgraded driver from the ATI site for the onboard video. It will not work. Change to the video driver on the CD that came with the motherboard, that should fix it for you... Just make sure you completely uninstall the current video driver before you install the one from the CD.
Jun 19, 2012 | MSI K9AGM-FID Motherboard
Is my linux computer compatible with windows xp software? are the parts interchangeable? example= installing a linux video card in a windows 7 tower?
Most devices that have Unix drivers will also have drivers available for some versions of Windows. Asus lists XP drivers for this board: http://www.asus.com/Motherboards/AMD_Socket_754/K8V_SE_Deluxe/#download . The K8V-SE Deluxe motherboard is not listed as Win7 compatible (but it's not listed as known incompatible either). To test if this board is Win7 compatible, update to the most recent BIOS, then use a Win7 install DVD to search for drivers and other support. (I know the Windows Update disc confirmed that my WinXP box would support Win7.)
For moving components into another computer, you will need to identify the exact device that you want to move and the slot/interface for that device. For example, since ASUS K8V-SE Deluxe motherboard has an AGP video card slot, it will not fit in a newer tower with only PCIe or PCI slots. If your Win7 tower does have an AGP slot, you may need to look in will amongst the drivers for "legacy cards". Finding an XP driver will be fairly easy. The Windows 7 driver may not exist and Win7 may not run without an external video card (if it can load at all).
I hope this helps. If you are looking at a different motherboard or wish to check specific components, please add a comment with the make and model of those parts. I'll be glad to try to find additional information. Include in your comment whether the Win7 tower is/will be running Windows 7 32-bit or 64-bit. Drivers for the 32-bit Windows are more common since they don't need the signature. (To check if a Windows machine is currently running Win7 64-bit, click Start > Control Panel > System and Security > System. If the title ends with x64, it's the 64-bit OS. Otherwise it's the 32-bit version.)
May 11, 2012 | ASUS K8V-SE Deluxe Motherboard
My volume and av mode touch pad do not work after i format and upgrade my laptop to window 7, vgn cs-16g
you will need the soundcard driver for Win7...for that you need to know the sound chip of the motherboard....if you Win7 is not original you can try the WinXP soundcard driver that came with your PC / motherboard
the best is to ....
if your Win7 is a valid original copy....!!!
go to MS website and register your Win7 copy and do an update....
the auto update will download the driver and install it
reg
kris
www.sureshayyar.110mb.com
May 08, 2011 | Computers & Internet
The card was working fine in windows xp. But i recently installed windows 7 and the card is not detected.
need a new driver for Win7 for the SB card....for Win7 HW mafgs have not develoepd any drivers as the Win7 source code was not provided to the Hw nfgs by MS....
MS has develoepd std drivers for all HWs that can install any HWs....
you need to register with MS your copy of Win7 and download all updates and the SB card will auto install once all updates are done....
Feb 07, 2011 | Creative Labs Sound Blaster Live! 5.1...
I GOT WINDOWS 7 FOR MY LG EXNOTE R560, AND MY SMART CAM IS NOT WORKING PROPERLY, IT KEEPS SAYING NO VIDEO DEVICE DETECTED,, AND I DONT HAVE A DRIVER,, PLEASE HELP IVE BEEN HAVING TROUBLE FOR A WEEK...
Some devices may still notbe compatibile with Win7, you will need to check to see if your webcam or PC manufaturer made an update driver to work with win7. Most of the time driver for Window Vista will also work. You can also try running window updates to see if it have a generic driver for it.
Jan 09, 2011 | Computers & Internet
No driver for scanner astra 3600 with OS windows 7
MS does not give driver with Win7....also most mfgs of hardware are not giving drivers to work with Win7....as you need to register with MS and downlaod the updates from Ms site...if your Win7 is found fake then the update will not work and driver will not get downloaded....
so MS is just making it more difficult for fake OS users to work with
Nov 01, 2010 | Computers & Internet
Lan drivers & draphic drivers are not installing. Im using win7
There are no drivers available or needed for this board under Win7.
Optionally you may use this tool (http://www.intel.com/support/motherboards/desktop/detect.htm) to detect any drivers you may be missing. Your biggest problem may be that Win7 hasn't detected your Lan card and update isn't possible. If this is the case try installing a USB Wifi Card and doing the update. Win7 will automatically find the drivers and install them for you with update.
Mar 07, 2010 | Intel D845GVSR Motherboard
I need drivers for WINTV PAL-1 44805 REV C135 conexant 878a
Here is a link for the drivers. Don't click on free download, it will install a driver update utility. Just click on the file name below that.
http://members.driverguide.com/driver_search.php?q=878a&company=247&device=4&si=c286053422677918981cd6f01f32f5f0&st=1463323226&ref=www_company_page&gqm0=878a+Graphics+Video+Adapter+Conexant
Mar 29, 2009 | Microsoft Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
