Bush a147cr6w keeps filling and display wont work
The machine starts filling and will not stop as soon as you try to select a program. Display lights up for 2 seconds then goes off. after about 2 mins filling up the drain pump kicks in for around 15 seconds then stops. but machine just keeps filling.
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 51 Answers
SOURCE: Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Posted on Jul 24, 2007
  • 19 Answers
SOURCE: Help anyone. Machine will only start for the first minute
F/05 Water Temperature Sensor Error If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed. Check the Water Temperature Sensor, Heating Element and Element Relay Check connections to the Sensor, Heating Element and Relay Hope this is helpful.
Posted on Sep 09, 2007
SOURCE: GLW10US won't do anything but beep
We love our new Bosch but... THE BEEPING IS TERRIBLE!!! I put a load in to wash when we go to bed. The beeping wakes us up. It is BAD!!
Posted on Jun 17, 2008
SOURCE: error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Posted on Jul 28, 2008
Miele w1913 simulation active on display when I press start/stop
Press and hold the Start/Stop button while switching the unit on with the On/Off switch.
As soon as the Start/Stop illumination ring lights constantly, after approx. 5 sec., release the Start/Stop button.
Immediately press and hold the Start/Stop button until the Demo-Mode is activated, approx. 4 seconds.
Demo-Program deactivation: Follow the instruction for Demo-Mode access above.
Aug 16, 2014 | Washing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
Washing machine fault
Too heavy, overloaded, off balance is my take from what you describe.
Mar 08, 2012 | Washing Machines
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Exactly the Same Problem
It's difficult to say without seeing the machine or having a failure code.
The machine looks for a switch to close as it fills with water. Maybe a pressure switch?
You could find the switch and see if it clicks when blowing into it and even test it with a meter.
That's an easy test.
Maybe the module has failed.
Hope it's given you something to look for.
regards
john
Aug 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
The machine (Automatic Breadmaker SD-255/SD-254) is plugged in and the display lights up but when I press the buttons but nothing happens - I cannot change the setting or start the machine.
Plug the unit in at the power outlet. If the display comes on, switch it off with the START/STOP button. After the display goes off, switch the unit on with the SELECT button. Remember that the START/STOP button is only used to start or stop a specific program.
Aug 02, 2008 | Kitchen Ranges
Washing machine.Fisher and Paykell Kelvinator
check the lid switch under the lower board they rust and the fault is normally not starting,or the display board can rust inside near the start/pause button if so try and unsolder a button you dont use and replace the start button.
Mar 03, 2008 | Washing Machines
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
