Question about Beko 24 in. D3421F Free-standing Dishwasher
Beko d3421fw no water coming in to dishwasher but everything sounds like its running
  • Samuel Charles Spriggs May 11, 2010
    Have you checked the inlet solenoid valve where the water supply line connects in the bottom of the machine?
3 Suggested Answers
  • 10865 Answers
SOURCE: no water coming in to dishwasher but everything
There are two possible reasons for the situation as you describe it: 1. Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
Posted on May 08, 2009
SOURCE: My beko eco care d3421fw dishwasher won't fil with
i have beko glacier fridge freezer.the freezer section works as normal but the fridge section only works sometimes.the pump only starts after you hear a click sound from the back of the fridge.is there a starter component that activates the pump.
Posted on May 24, 2009
I have a beko de 2762 fw dishwasher when i press start 3 out of the 4 lights come on and the moter continually runs.
It sounds like you have a leak. You need to take the dw out and lean in back untill the water will run outside.
Dec 16, 2013 | Dishwashers
When we switch our Beko DE 2541 on its running straight away with the stop/start button being pressed. On the last successful cycle completed it just carried on making a noise like it was running and has...
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. Then see if you can see where the leak is coming from. Hope this helps.
Feb 23, 2011 | Beko Dishwashers
Everything comes out cloudy
too much detergant or not hot enough water
Jul 01, 2010 | Beko 24 in. D3731F Free-standing...
Water is not going into beko dishwasher de2542f .you can hear and feel water going through the pipe but is not going into machine
My BEKO dishwasher is turned off but there is a constant dribble of water running in to the machine. If I open the door when this has happened, it leaks water all over the floor. This means I have to keep turning the machine on to drain the water away.
Feb 06, 2010 | Beko 24 in. D3731F Free-standing...
May 22, 2009 | Beko 24 in. D3421F Free-standing...
Beko dishwasher wont start it comes on wont fill up
hi there...have you checked the water supply to the dishwasher.......sounds either no water to the appliance or a faulty water inlet valve to the appliance
regards Sir Galahad
May 15, 2009 | Beko 24 in. D3421F Free-standing...
No water coming in to dishwasher but everything sounds like its running
May 08, 2009 | Beko 24 in. D3421F Free-standing...
Beko washing machine fills with water when not in use!!
hi there.....you got a faulty water inlet valve on the machine ..change this and all will be fine again...
regards Sir Galahad
Dec 05, 2008 | Beko 24 in. D3421F Free-standing...
Beko eco care d3421fw
Check that the water is on or you haven't squashed the hose or there maybe an airlock in it.
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Beko 24 in. D3421F Free-standing Dishwasher Logo
106 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
