There are two possible reasons for the situation as you describe it:
1. Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2. Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
beko d3422fw program 3 or 4 starts gives rinse and stops doing anything. Pump running but never...
(More)
beko d3422fw program 3 or 4 starts gives rinse and stops doing anything. Pump running but never seems to heat up either. pointer as to whats wrong please.
beko dwd 4310w. fails to drain. filters clean no blockages. green light comes on but no sound when...
(More)
BEKO DWD 4310W. fAILS TO DRAIN. fILTERS CLEAN No blockages. green light comes on but no sound when set programme
a glass shatterd on a cycle and iv dug out as much as could but i can her it pumping round seems...
(More)
a glass shatterd on a cycle and iv dug out as much as could but i can her it pumping round seems like its clattering against the pump how do i get to it when i open the back up
my beko dishwasher starts then after a few seconds all power goes then comes back on this keeps...
(More)
my beko dishwasher starts then after a few seconds all power goes then comes back on this keeps repeating
why does my beko fridge smell inside like stinky cheese but i dont have cheese in it the fridge is...
(More)
why does my beko fridge smell inside like stinky cheese but i dont have cheese in it the fridge is oniy 6 months old
