Question about Ovens
Thermador scd302tp display lights dim
Oven works but display is very dim
Rotu
  • 175 Answers
SOURCE: Oven timer and temperature display dim
You need a new display/relay board package they have come up with to solve this problem. The parts generally run about $250, and if you have it repalced by a service company, the total will be a little less than $500. The display is really easy to change by itself, but you must change the realy board with it, and it has about 40 different wires going to it. If you draw a diagram as you take the wires off, and label them carefully, it isn't that hard to do the whole job..just take your time. This is a problem thermadore/dacor ovens have had for some time. If it isn't too old you may try calling thermadore and see if they are willing to at least buy you the parts, as this is a known problem. Good Luck!
Posted on Nov 24, 2006
  • 6 Answers
SOURCE: Thermador SC301T oven
Thermador SC301T and SC302 stack ovens have a weakness in the radial capacitors on the circuit board behind the LED clock. They get cooked from heat. Here is the fix: Remove two screws from the control panel, located facing up at the bottom on the panel frame.. open the oven door to see them. The panel is then held in place by push in toggles at each end, pull towards you to remove. Carefully unplug the three wiring harness plug-ins, and check them to see if any wires are loose. Set the panel aside. Remove 3 screws holding in the LED assembly, and again unplug the wire harnesses, examining each for loose wires at the terminal. When unplugged, take the LED assembly to the bench, remove the plastic housing, and with a mini soldering iron and watchmaker's eyeglasses, or hobby magnifier,
identify, heat, and remove two 35v 450uf 105 degree radial capacitors, and one 35v 68uf 105 degree
capacitor. These are ordered from MCM Electronics (google it) and are p/ns 96K0326 and 96K0331.
Insert new parts, solder and clip excess leads. Carefully examine the printed circuit board around the area of the leads you just soldered, as some boards do not have the copper close enough to the hole to make contact. Scrape the green insulation from the conductor near the hole to expose copper and make sure your solder makes contact with the copper and the lead. Use your multi-tester when finished to check continuity from all leads you just soldered and their nearest neighboring contact on the circuit board. I found a loose wire on the harness to repair, and one contact on a capacitor did not have the copper close enough to make contact without extra effort. When all is completed, reassemble. Turn back on power at the circuit breaker. You may get an F7 error code. Off with the power again, wait 3 minutes. Restore power, go to oven and press the OFF position on the glass control panel... hold for 10 seconds, and the clock should now be steady at 12:00. Push clock position, reset clock for proper time. Test oven light on/off. Test bake/temp/convection buttons,
on/off. This is a good fix, and will save you about $469.00 in parts and $500.00 in labor. The new
105 degree centigrade high temperature radial capacitors replace old 85 degree, which fail, and your repair should last. Total parts and shipping costs.. about $10.00.
Posted on Mar 14, 2009
  • 114 Answers
SOURCE: Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Posted on Mar 21, 2009
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
SOURCE: thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
theblog
Posted on Sep 19, 2009
Thermador oven control panel light is very dim
FixYourBoard.com fixes this problem, and they back their work with a two year warranty!
See the photos of what your new display will look like below.
Feel free to ask questions-- info@fixyourboard.com
Apr 24, 2017 | Thermador Ovens
Where can i find a relay board #492069 for thermador model SCD302TP?
try having it rebuilt at core centric solutions dot com. they bring new life to most old electronics.
Feb 09, 2013 | Thermador SC302T Electric Double Oven
I'M LOOKING PART OF THIS MODEL Thermador SCD302TP
Hello, welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door seal for your SCD302 series Thermador double wall oven. They should have anything you need.
http://www.repairclinic.com/Model-SCD302TP-ID-642642-Parts
Thank you for choosing FixYa and good luck. Please take a moment before leaving to rate the assistance provided here and your experience at FixYa.
Regards,
Macmarkus :)
Sep 19, 2011 | Thermador SC302T Electric Double Oven
The control panel is very dim on my Thermador RDSS30 oven
Cannot Read Display or See Temperature Thermador RDDS30
FixYourBoard.com repairs this failure and back their work with a two year warranty.
May 14, 2011 | Thermador Ovens
I have a thermador oven m#SCD302TP reading F2 F5 // HELP
F2 -Oven temperature too hot
Replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).
Thank You
Sep 03, 2010 | Ovens
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
Nov 14, 2008 | Thermador SC302T Electric Double Oven
Thermador oven display is dimming
theblog
Nov 29, 2007 | Ovens
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Ovens Logo
188 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
