Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
Chain saw starts but stops when you feed gas
Chain saw starts but stops when i feed gas it bogs down and shuts off
rwvanlue
  • 486 Answers
SOURCE: Husqvarna chain saw Model 141 running at high rpm's
You may wnat to inspect the intake manifold/boot that mounts inbetween the cylinder and the carb. Also, the impulse tube that comes from the bottom of the cylinder to the carb manifold or carb itself. Sounds like you are running a lean condition. You need to locate the source very quickly, or continued operation will permantly damage the saw. I have listed a few other things to check.
Please let me know what you find. rwvanlue
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 13, 2009
  • 135 Answers
SOURCE: while cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Posted on Jan 02, 2010
dontbother10
  • 2220 Answers
SOURCE: my husqvarna chain saw bogs down even without chain on it.
I think your "L" adjustment is off by a little, but because it will not hurt, costs nothing, and might be the cause of this, remove, clean and reinstall the muffler and spark arrestor. If the problem persists try this, it is by far the best carburetor adjustment I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. Good Luck. HTH
Lou
Posted on Feb 24, 2010
hunter19_46m
  • 7482 Answers
SOURCE: chain saw bogs down as soon as it is given gas but
Hi finalproject...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters and chainsaws.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the chainsaw is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Posted on Aug 18, 2011
  • 2239 Answers
SOURCE: I have the 455 rancher and when I start the saw I
Before you do anything else i think you need to check the engine is mechanically sound, remove the muffler, take a look at the piston skirt through the open port, any signs of scuffing on the piston and it will require removing the cylinder to assess the damage, they are x torq engines, due to the way the air ports work they are quite prone to carboning in the piston rings, make sure it has plenty of compression.
Posted on Aug 21, 2011
How to adjust carburator on a mac 130 chain saw
turn till it stops clockwise, then turn back counter clock about 1 1/2 turns. If you hear the motor sounding bogged down, turn it a bit more counter clockwise, (leans out the gas) till it stops sputtering .
Jun 21, 2014 | McCulloch Garden
Starts fine, runs fine (full throttle) for about 30 seconds and then just bogs down when throttle is depressed (or still held in). But still idles fine after it has warmed up a little.
More than likely it is your fuel line collapsing. When the rubber gets stretched, worn, aged, or run on gas with 10% alcohol, especially the last, the rubber gets weak and collapses on itself at full speed. That is why it runs till the suction collapses the line but still allows enough through to idle. Once the saw is shut off the line will fill up again when the suction stops and you can run till the line is empty again. It is worse if your filter is clogged also. Went through this when they came out with this crappy gas in the late 1980's. Had to carry spare fuel lines while logging because the lines could not take the alcohol. That is why I burn airplane fuel in my saws. No alcohol or storage problems. If you look up around Oct 1 or 2 I wrote how to change the fuel line. Hope this helps.
Sep 10, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
I have a husky 371xp. the saw will fire up and rev up and down on its own with out me giving it gas. then once i do give it gas it will bog down and shut off. could i have some bad seals? or whats the...
Irractic and high idle is normally an air leak, so yes it could be crank seal leaking, or the induction tube cracked, or the impulse tube from the crankcase to the carb cracked, or the cylinder base gasket blown out.
Jul 08, 2011 | Husqvarna Chain Saw 20" Bar
My 455 rancher bogs down when i give it gas it's not even under a load new plug air filter, fuel filter, made carb adjustments like manual said running 93 octane gas.it,s still bogging
Make sure the chain break is releasing all the way. When the saw is not running release the chain break and make sure you can move the chain back and forth by hand. If you can there is a small fuel filter in the gas tank that should be replaced. Make sure the fuel lines are not spongy because they could collasp when the engine is running starving the carburetor for fuel.
Mar 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
What causes the chainsaw to bog down and chain to stop when under light load
check chain is sharp oiled and tension is not too tight.if sawis old check engine compression is not low.
May 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My husqvarna chain saw bogs down even without chain on it.
Lou
Feb 24, 2010 | Husqvarna Forest & Garden No.967012396 345...
While cutting the chainsaw bogs down and stops
Jan 02, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
McCulloch chain saw wont stay running after it warms up. I go to cut wood it start to bog down if i let go of the button it idles fine
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
