Router works--wireless reads connected, but inet explorer reads webpage cannot be displayed
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Open IE, select tools, internet options, select the connections tab, click the LAN settings button, select Automatically Detect Settings. Restart your browser.
Select Start, Run, type "cmd" and enter. At the command prompt, type "ipconfig /all", find your wireless adapter, verify the DNS entries are not all 0's and the gateway is populated with the IP of your router.
If the above doesn't work, browse to Control Panel, Network Connections, wireless connection properties, TCP/IP properties. If a static address is not required, select Obtain IP automatically and select Obtain DNS automatically.
Posted on May 08, 2009
  • 3,267 Answers
Check the DNS settings and get it confirmed by your ISP....sodeep
Will not connect to the internet. It is connected to the wireless; however, will not connect to the internet. Says: Internet Explorer cannot display the webpage. other computers on the same wireless can...
How is your internet security set? Try resetting your router to factory specs and see if your laptop works. I know it seems weird that only one computer wont connect, but try a different router, and try a different security setting within your wireless router.
Jul 15, 2011 | Dell Inspiron E1505 Notebook
Tip
Hi, I want to use the LINSYS Router as an alternate wireless acces point. I´ve...
'I've forgotten the router password,' is a common problem. But first, which password do you need?
  1. If you want to login to your router, to view or change settings - you need the router login password.
  2. If you want to connect (say) a new laptop to your wireless internet connection – you need the network key. This is the encryption key used to secure your wireless signal. Windows asks for this key when you try to connect.
Here’s a rough guide to what to do in each case. For detailed instructions, check your manual. If you can't find a manual, follow the tip How To Find A Router Manual. (NB: You don't have to read the whole manual - just check a few details, as described in the tip).
1) Retrieving a lost network key - so you can connect (say) a new laptop to your wireless network:
i) Login to your router. Do this by entering http://192.168.0.1 or whatever is correct for your model, into a web browser. Enter your router username and/or password at the prompt.
If you don’t have these, see Step 2, ‘Retrieving a lost router password’.
ii) In the screen that you see, go to the section headed Wireless, Security, or similar. Every router is different, so you may have to hunt around. Key words to look for are Security, Wireless Settings, Encryption, WPA, (or WEP).
Your network key will be here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK etc – but that’s the one you need. Now you should be able to connect to your wireless network.
Tip: Write the network key on a label, and stick it to your router.
2) Retrieving a lost router username/password- so you can login to your router, to view or change settings:
i) First, see if there is a label on the base of your router, showing the correct username and password.
ii) Otherwise, try the defaults and see if they work. Common default usernames are admin, or blank (ie type nothing, just leave blank).
Some common default passwords are password, admin, 1234, sky (for UK Sky users), or blank (no password). Check your manual for this, or try a Google search. It’s important that you find the correct default password for your router.
iii) Defaults don’t work? You will have to resort to a hard reset.
Beware. If you perform a hard reset, your router will be back at factory defaults. Your router login password will then be the default, BUT you will normally lose all your router settings. If you have a combined modem/router you will also lose your internet connection, until you have set up your router again.
If you are very concerned about this, ask the person who set up your router to help you.
Otherwise, you can do it yourself . Every router and ISP is different, but if you have your ISP login details and your manual (see How To Find a Router Manual ) - you should be OK.
Your ISP’s website may also have info which will help you - why not take a look. Similarly, your router manufacturer’s website may offer easy install software, and setup tips, if you need them. Print off any online information you need before performing the reset.
iv) To reset - ensure you have a wired (ethernet) connection to your router, and that it is switched on. Find the router reset button, which may be an unmarked pinhole, often on the back of the router. Press and hold down the reset button as long as it takes to reset the router. This is typically 10 seconds or so (check the manual).
v) You can now use your default password to login to the router, and set up your details afresh.
I hope this tip helps you. Losing a password is a pain, and we've all done it. But - armed with your router manual - you will soon be up and running again.
All information is offered as is, without warranty. If you choose to use it, it is completely at your own risk. If you are in doubt, consult a local professional. Thanks to all Fixya contributors who helped with this tip. Updated Dec 09.
on Feb 20, 2009 | NetGear DG834G Router
I cannot read my e-mails it says internet explorer cannot display the webpage
hello.
-it is saying "internet explorer cannot display the webpage" may be internet is not working you can call Internet service provider or try steps below.
-make sure the the modem and router is on -make sure cable is connected if you are using the LAN cable. -make sure that the wireless switch from the computer is on for wireless internet connection.
-other provabilities why you cannot check mail if the Internet explorer is not working properly or if there is an virus or infection that is preventing you to go online.
Cheers.
Feb 25, 2011 | Computers & Internet
The remote device or resource won't accept the connection
Try restarting your router. If that doesn't work than check if you didn't accidentally hit the wireless button on your laptop as many people tend to do this and not realize it.
Apr 09, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Wireless connected but internet not working.
try opening ie then clicking the file tab, look to see if there is a tick next to 'work offline' if there is then uncheck it.
Feb 28, 2010 | Acer Aspire One Netbook 8.9" Notebook
Connection
Make sure the router wep and pc wep have same password. Ocassionally the wireless properties settings need to altered and the IEEE box unchecked.
Oct 08, 2009 | Computers & Internet
I have an HP Laptop LAN connection will not connect to internet
The wireless modem you are connecting to is protected with a WEP key. You have to get the WEP key or find another wifi hotspot that is not protected.
You can also get a better antenna for your laptop to see if you can pull in another site.
Jul 30, 2009 | Dell Inspiron 1501 Notebook
Connected but cannot access internet
If you have a good IP address, re-boot the router. If your address starts with 169., then you don't have a good IP address.
Jun 03, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Internet Explorer can not display this webpage
This is not Internet Explorer's fault, this is a bad network connection. I presume you have wireless because I experience the same issues occasionally when my wireless connection drops out. The only solution to this is either use an ethernet cable from the router to the computer or move the computer/router closer to each other or get a further reaching router. Hope that helps!
May 10, 2009 | Computers & Internet
Wireless connection, but no internet
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel
- Open the network connection
- Right click on wireless networks (Choose properties)
- Choose Internet protocol then click properties
- Assign DNS Server address (Preferred DNS: 4.2.2.2, Alternate DNS: 4.2.2.3)
- Leave the DCHP as obtain IP address
Mar 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
David Payne
David Payne
