Question about Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
Intermatic T101 24 hour dial switch not keeping time
  • Paragon Master
  • 5,245 Answers
Intermatic dial doesn't automatically switch sprinklers
1) Trippers can wear down. Transformer can go bad if model has 24Volt output. Relay can go bad.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
2) Add a comment Feb 2013 with model number, and include if this is new timer or older timer that worked before and stopped working.
Feb 10, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
Hi, I have few quick questions regarding the Intermatic HB114C 240 Volt, I would appreciate if you can answer my questions 1. Does this unit have Internal Built in Clock to set up the Clock or does...
HB114C timer likely will not work in India.
Contact Intermatic: http://www.intermatic.com/customer%20service.aspx
Plug type is different than found in India.
India power generation is 50 Hz, so timer might not keep time even with plug adapter.
US power grid is 60Hz, so US-sold products are 60Hz.
Some timers are both 50Hz and 60Hz, but spec sheet usually shows that information.
HB114C spec sheet does not show Hz.
http://www.intermatic.com/~/media/files/intermatic/products/fact%20sheets/timers/hb114c.ashx
http://users.telenet.be/worldstandards/electricity.htm
HB114C is analog appliance timer with clock motor that rotates dial once every 24 hours.
The timer does not have a countdown feature.
Trippers are placed on dial.
As dial rotates, trippers move small switch that opens and closes circuit to load.
Current time is set by manually rotating clock dial until current time lines up with arrow located on inner dial.
After power failure, current time must be reset.
There is no way to install a battery back-up inside the timer.
To see images
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
Aug 15, 2011 | Intermatic HB114C Heavy-Duty Timer
Can't figure out how to set the times to turn power off/on.The metal trippers seem to be permanently in there.
Remove dial from body of timer.
So now the timer is apart in 2 pieces.
Silver ON trippers and brass OFF trippers can be removed.
Place trippers in times you want timer to operate.
OFF trippers have to be at least 2 hours apart.
ON trippers have to be at least 2 hours apart
Minimum on-off function is one hour
Snap timer back together.
Tripper rotates around with dial.
When tripper contacts on-off lever, it physically moves lever like turning on light switch.
ON tripper moves lever one direction.
OFF tripper moves lever opposite direction.
Manual E-1020
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1020%20-%20english.ashx
Dec 11, 2010 | Heavy Duty Intermatic Wall Switch Timer...
HOW SET TIME ON AND OFF
You posted under intermatic 1020 timer
If this is not your timer, add a comment
How to set timer.
Rotate dial around until current time lines up with mark
Dial rotates with passing time.
When tripper contacts on-off lever, it physically moves lever like turning light switch on-off.
Manual E-1020
Dec 11, 2010 | Intermatic Timer E1020, Single pole/single...
I need the instructions to do the set up
You posted under Intermatic TN300 24-hour plug-in indoor timer with 2-prong outlet
http://www.amazon.com/Intermatic-TN300CL-Indoor-Mechanical-Timer/dp/B001KBZUK8
Intermatic TN300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn300.ashx
TN300 is same as Woods 59200
http://waterheatertimer.org/pdf/Woods-59200.pdf
Rotate dial until current time lines up with arrowhead located on inner dial.
The segments located around edge of dial are pushed down or raised to set on-off times.
Push segments down for times you want timer ON
Override switch on top of timer.
For programs to operate, move switch to Timer ON
Plug lamp into timer.
Turn lamp ON
Plug timer into wall
Dec 09, 2010 | Intermatic 10 Amp Mechanical Indoor Timer
How do you set this timer
http://www.intermatic.com/products/timers/in-wall%20timers/24-hour%20mechanical%20time%20switches.aspx
Timer shown is E1020 or E1010
This timer wires into a wall box
Grasp time dial firmly and pull until it comes free from timer.
Remove all silver ON trippers and brass OFF tripper using pencil or paper clip
Program the timer by inserting trippers
The minimum set time for this timer is 1/2 hour
OFF trippers should be spaced at least 2 hours apart from another OFF
ON trippers should be spaced at least 2 hours apart from another ON
Push time dial back onto timer
Current time lines up with time line located at top of timer dial
Next to the time line is the manual override.
Use manual override to reverse the timer program, so if lights are OFF, manual override will turn them ON.
Oct 28, 2010 | Heavy Duty Intermatic Wall Switch Timer...
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
Programming
Use this procedure to manually program ON/OFF settings.
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previous time settings will be cleared from memory.
1. Move the control lever to the ON position. The Red indicator light will start fashing.
2. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time. NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will accidentally set a wrong time.
3. Press the dial once to set the present time. The Red indicator light will go off.
4. Rotate the time dial clockwise to the frst desired ON time.
5. The Red light will pulse momentarily with each click.
6. Press the dial once to enter the ON time. The light controlled by the switch timer will turn ON.
7. Rotate the time dial clockwise to the desired OFF time.
8. Press the dial once to enter the OFF time. The light controlled by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting. Continue to rotate the time dial until the Red indicator light comes ON and stays ON, indicating that the switch timer is in AUTOMATIC mode
Sep 26, 2009 | RTO Intermatic Inc Ej351c Timer Night...
Paragon 4001-00 24-hr Timer Control 120v Ac Cd101 Logo
163 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
