Question about Miele 24 in. G656SCi Plus SS Built-in Dishwasher
Inlet/drain red light flashing
Have cleaned non return assembly-red light still flashing
gwshaw71
  • 83 Answers
SOURCE: Inlet/Outlet light flashing
check your overflow level switch wich is located behind front kickplate on right hand side
Posted on Feb 24, 2008
  • 4 Answers
SOURCE: Inlet/Drain light keeps flashing
Kenyanjoe, I have had the same problem with a G638 . the inlet/drain light flashed 30 sec after start up, (the machine must empty on start up, this did not happen), This caused it to lock out on alarm I removed the drain hose from the S trap,removed the non return valve from the filter, check the drain pump impellar is free, then blow down the drain hose back into the dishwasher to make sure it was not blocked then found the drain pipe on the S trap under the sink was restricted causing the machine not to empty in time for the cycle to continue causing it to lockout on inlet/drain alarm. Have a go , good luck. GUNNO
Posted on Apr 02, 2008
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Posted on Aug 14, 2009
joe_lishman
  • 192 Answers
SOURCE: Inlet/drain light flashes on miele dishwasher and
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Posted on Jan 17, 2010
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Miele dishwasher Model G1023 drain light stays on and dishwsher will not work
Hello fellow DIY'ers,
Have just had the red light drain/inlet error terror!
Tried all the basics, including:
- check and clean inlet hose filter,
- check and clean drain hose,
- remove and clean all the filters in the bottom, and
-remove and clean the non-return valve.
Still was left with water in the bottom at the end of the wash and the red light drain/inlet error.
After researching further I found that this light also indicates a flooded unit. There in a shallow pan in the base plate and if water collects there it activates a float switch, stops the wash, and lights up the drain/inlet error.
To fix it:
- Disconnect power, water and drainage.
- Pull out your dishwasher, suction/remove all the water from the bottom. This includes the water in the salt reservoir, the drain pump and non-return valve.
- Tip the dishwasher onto its back.
- Remove the four star head screws (sometimes a small flat blade screwdriver will fit these) from the base plate.
- Remove and inspect the base plate. It won't have any water in it as you've just tipped it up. But you will see if it's wet and any staining where the water has sat. It only takes a small amount of water to activate the switch.
- Clean and dry the base plate.
- Have a good look around for leaks in the base of the unit. There was none in mine. Our dishwasher is a snug fit under the bench and we had been doing 2-3 washes per day for several humid weeks leading up to this problem. I believe the water builds up over time and doesn't get a chance to evaporate.
- Put it all back together again and test it.
- If it works, go buy yourself/your family dinner because you just saved yourself about $420!
Regards,
DIYTom
Aug 25, 2011 | Dishwashers
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Feb 22, 2010 | Miele 24 in. G653 SCVi Plus Built-In...
Inlet/drain light remains on
I have the same problem on a Miele G647 SC Plus. It starts and completes the wash cycle, might skip a final rinse - not sure, but it drains the water. Pump then continues to run for extended period then inlet/outlet light comes on. The dishwasher never moves to the drying cycle.
I cleaned all filters, checked supply/drain hoses + the non return valve. All seemed servicable. But no real improvement in fault.
Any way I can fix this?
Jul 30, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Aug 14, 2007 | Miele 24 in. G693 Free-Standing Dishwasher
Jul 11, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G656SCi Plus SS Built-in Dishwasher Logo
21 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
