Question about LG LFX25960ST Stainless Steel French Door Refrigerator
I have a LG lfx2590st refrigerator the light inside won't turn off
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
Hi, very recently my LG refrigerator stopped working (how convenient for LG that it pooped out on me once the warranty expired a week or two ago). I don't hear the motor running and all the lights inside...
in most cases its a problem with the thermos control system this is the main device that turns the compressor on have it checked to make sure its working
merry christmas
please take the time to rank this advice
Dec 25, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
Cabinet not cooling, when i go through the test sequence the cabinet works perfectly the display shows all lights illuminated is this a sensor fault and if so where are the sensors?
The lights inside the refrigerator are not turning off when you close the door .
The light switch is broken. replace the door operated light switch.
Nov 26, 2010 | LG LRSC26920TT Side by Side Refrigerator
Refrigerator light stays on ?
LG has a wonderful way of turning on their refrigerator lights, they have the control board do it. Very nicely done in theory but in reality I would trust a handy door switch to control the light on/off function then a relay that get's stuck. That's right, the relay is stuck on the control board. Pull light bulbs out quickly before plastic melts on the inside top panel of fridge. Call LG, it should be covered under warranty.
Nov 24, 2010 | LG LFX25960ST Stainless Steel French Door...
My refrigerator LG GM 313SC wasn't working yesterday, I disconnect the refrigerator and notice that the compresor was too hot, I reconnet the refrigerator at night and in the morning checked the compresor...
I have 2 of the LG GM 313SC. Purchased brand new here in the Caribbean (Dominica) Both units when I turned them on for the first time are making a 'clicking' noise that is happening together with blinking lights on the temperature control inside the fridge section.
It isn"t even turning on. The light inside is dim, which the manual says is an indication of a problem, and to call an electrician. I think not, they are brand new and behaving the same way.
Any suggestions
Oct 21, 2010 | LG Refrigerators
The lights inside the fridge will not turn off. The alarms on the door still work, if left open for too long, but the lights don't turn off.
Unscrew the bulbs. These LG refers have had a problem with this they had to revise the main control board and added a terminator to the light socket harness. You will need a new board and light socket harness. Call LG they know of this problem and they may assist in the repair.
Oct 20, 2010 | LG Refrigerators
LG refrigerator compressor/lights won't turn on
You have a bad main board call LG service and discuss your options.
Nov 29, 2009 | LG LSC26905TT Side by Side Refrigerator
Interior light wont turn off
tHE PROBLEM IS CAUSED BY A BAD MAIN CONTROL BOARD LOCATED ON THE BACK OF THE REF AND IS COVERED BY A PLATE WITH A BUNCH OF SCRREWS. ALSO, LG HAS EXTENDED THE WAR TO COVER UNITS PURCHASED IN THE LAST 3 YEARS TO CORRECT THIS PROBLEM. CONTACT A LG DEALER OR CALL THE COMPANY TO SEE IF YOU ARE COVERED BY THIS WARRANTTEE REPAIR
Dec 02, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
