Question about Dometic Rooftop RV Air Conditioner
Air conditioner The ac was running great, my husband turned it off now it will not turn on...we have had a problem with the generator cutting out when turning on a load, but the ac will not even turn...we just bought the rv and see the ac needs a good cleaning and we are going to clean the carb...could the problem be connected or is there a reset button, we did check the fuses and they seem ok...any advice would be appreciated.
  • 83 Answers
Airconditioner compressors has so little voltage tolerance, if voltage is lower than its rated, it will not run at all. I suggest you let the generator run at full first before turning on your airconditioning.
Posted on May 08, 2009
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
Oct 29, 2011 | Dometic Rooftop RV Air Conditioner
Recently purchased a 4400W generator to operate travel trailer primarily and on occasion my ac unit. Connected the generator to the travel trailer, then ran the a/c, everything going well, then the circuit...
What size circuit breaker is on the generator that is tripping? You'll need a 20amp for AC alone, then consider other things that are drawing current when RV plugged in like , converter, fridge etc that may be drawing current at same time. Make sure fridge is on propane, as well as water heater if you have electric element option on water heater. AC may only draw 12-15 amps when running if good and clean and wired properly, but will draw 17-18 amps when compressor kicks in. Perhaps generator not designed for that surge?
Aug 28, 2011 | Dometic Rooftop RV Air Conditioner
2007 dometic Rooftop AC "high-lo" switch. What does it do?
YES WITH OUT A DOUBT .. DO NOT TRY TO RUN IT ON HIGH IT MAY DAMAGE YOUR GEN SET ... HELP ? PLEASE VOT
May 28, 2010 | Dometic Rooftop RV Air Conditioner
I have a AZ38H15DADM1 that works fine in heat mode and in AC mode it works great until it reaches the temp it thinks it should be, then it cuts off and never cuts back on without me physically turning the...
When setpoint is reach unit would shut off .
If you put the fan to the ON position it would run all the time and ac would cycle on and off depends on the temperature
Feb 12, 2018 | GE Zoneline AZ38H12DAD Split System Air...
I'm running my RV 115V 60hz a/c while connected to a 4,000 watt gas generator, with no other loads. The A/C has constant cold air, but seems to have an oscillating sound. The trailer is not completely...
this is normal, do not worry that harmonic vibration type noise just tells me that the unit has a full freon charge and is running great, sit back and enjoy
Aug 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Duo Therm Ac, Fan runs, Compressor cuts in and out?
your compressor is locked up. i would try replacing the round start capacitor. you need to check what the exact rating for yours is but I believe one of these two will work for ya. In the meantime do not continue to try to run it, it will kill the compressor.
seth
53-64 mfd
45-53 mfd
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Run ac off of generator.
you need to use a volt meter and test which lead from the 4 wire output of the generator a 220 v is coming out.
the round center prong of the ac is its ground and should not be connected to any live power. it could be left unused.
tnx 4 using fixya,
drcool
Sep 27, 2008 | Hampton Bay HBLG5004 Air Conditioner
Circuit Breaker and Dometic Rooftop RV Air
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Jul 20, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
147 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
