Question about Xerox DocuColor 12 Color Copier
DocuColor12 printing yellow color only
Also displaying message Turn power to the printer on?
help is very appreciated.
    Problem Solver:
Download a patch for this problem in Xerox page!!
Posted on Dec 29, 2007
  • 56 Answers
To fix
Turn Print Power On Message:
press "0" and "start" button at the same time.Then you are in login screen.
After that you have to enter "6789" and press "confirm" on touch screen.
Now just select dc 131 NVM read/write buton.
You are in NVM read /write screen now.Select input number and type:
"759053" (759-053) ,select "read" to see current value.
Type "1" , and press start(Big green button)
repeat same procedure for adress:
759054 (759-054) Type 1 and press start.
After that select "close" and "done" buttons to get normal operation screen.
For yellow only printing :first try to print after get normal operation screen.
if no results,switch off Fiery and DC12,disconnect power cables,disconnect all cables from fiery and machine.
reconnect cables,and power on both,then print.
Posted on Nov 02, 2007
    An user who is expert in 3 categories / brands.
  • Xerox Master
  • 1,362 Answers
Only printing Yellow
Please See The Vedio On Youtube
By This Time i Fixed My Problem,
HP 2500 color only prints yellow
Follow Us On
HP Printer Support
Jan 08, 2014 | HP LaserJet 2550n Printer
I've encountered an Incorrect Yellow message upon turning on the printer HP2820
The printer would only display messages of functions commonly as ink shortages. For example, color printers with encountering ink shortge would display a message. However, continuing to print would produce least impressive cooration where for multicolored characters tend to appear in yellow. Also, printers with ink malfunctions require inspection of cartridges, ribbons, and compartments for mal alllignments. Readjusting the ink compartments would request performing test print sheets as reallignment check. At which situation, a continued malfunction would be detected as diagnosable by computer popup messages. Refer to the printer user guide. Good luck
Jan 11, 2011 | HP Office Equipment & Supplies
Poor color on papper & photos brand new ink tried everything
Epson R360. Printer error. Please see your documentation?I have an Epson R360 and attempted to print a cd. As I put the tray in the printer didn't respond, when I looked at the screen the display was showing a message, " Printer Error. Please see your documentation" It advises to turn off and turn on again which I have done, several times. It was working directly before this as I had printed my daughters homework.
I uninstalled the drivers and reinstalled them to see if it would make any difference, but nothing. My printer just keeps telling me this message. When I power it up there is a lot of noise coming from inside the printer, the ink carriage is moving but not a great deal. Any help advice is appreciated.
Apr 26, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Epson Stylus CX6600 does not print
Suggest you try resetting the waste ink counter on this printer to see if it will then allow it to print again.
  1. You will see big button on your printer like power on (this is on the left
  2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
  3. first turn off your printer
  4. push the b/w + color + stop buttons together and hold
  5. push the power on button and hold (so you'll now be holding down 4 buttons together)
  6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
  7. release all the buttons
  8. push the color button (once)
  9. turn off the printer
  10. turn it on again
IF this works you will then need to fit an external waste ink tank as soon as possible to ensure you don't end up with a major headache (ie: ink swimming pool!) under your printer.
Instructions for completing the modification are available if you google your printer model and "waste ink".
Jan 17, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Near empty yellow
    Do print until the message EMPTY (Printer stopps printing). DO NOT refill or change cart when message is shown: NEAR EMPTY! You fool the printers logic. Machine counts down the rest of the ink in the cart. When you refill at that moment the counter is disoriented! To clear the counter: Unplug powercord. Take carts out. Wait 3 min. Plug in power. Machine demands carts. Do use carts at full level (refill before you put them in). Works normal afterwards.
    Sep 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
    Xerox DocuColor 12 Color Copier Logo
    209 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
