Question about Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer
Auto set @ dusk does not come on
Will not turn on @ dusk
Where can I get a dusk till dawn timer master plug did one that I wanted a TDD-MP but cannot get them anywhere so now looking for a Paget dtd timer where can k get one
  • No Paget, but lots of others
  • DUSK TILL DAWN LAMP TIMER - Nexus Industries www.nexusinds.com/masterplug/downloads/pdf/TDD.pdf · PDF file DUSK TILL DAWN LAMP TIMER SWITCHING MODES i) Timer mode ii) Random mode iii) On mode iv) Off mode v) Dusk 'Til' Dawn mode i). Timer Mode The timer will turn ...
  • Dusk to Dawn Timer ' eBay > www.ebay.com/bhp/dusk-to-dawn-timer Find great deals on eBay for Dusk to Dawn Timer in Light Timers. Shop with confidence.
  • images of dusk till dawn timer bing.com/images b3eo0&w=105&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">551o0&w=60&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">6f9o1&w=72&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">595o0&w=99&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">773o0&w=107&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">fcfH0&w=72&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2"> See more images of dusk till dawn timer
  • Dusk to Dawn Photocell Sensor Timer Switches 10.02 www.acetek.co.uk/id66.html Acetek manufacture Dusk to till dawn photocell timer light sensitive sensor switches for energy saving lamps LED 6v 12v 24v and 240vAC
  • Dusk Till Dawn' Self-Dimming Lighting. - D-D The ... www.theaquariumsolution.com/files/Dusk Till Dawn Instructions... · PDF file 3 Step 4 - Synchronising Programme with the Plug Timer It is necessary to synchronise the Dusk till Dawn chip to the time of day during which the unit has been ...
  • Amazon.com: dusk to dawn timer www.amazon.com > Search > dusk to dawn timer Amazon.com: dusk to dawn timer. Amazon Try Prime All Go. Shop by Department. Hello. Sign in Your Account Sign in ... after 2,5 or 8 hours / Dusk to Dawn default timer
  • Items found similar to "DUSK TILL DAWN PHOTOCELL ... - eBay www.ebay.ca/sch/sis.html?_nkw=DUSK+TILL+DAWN+PHOTOCELL+SENSOR... Photocell Timer light Switch Daylight Dusk till Dawn Sensor Light switch G8. ... 5 Pcs Dusk To Dawn Photocell Light Control Auto Sensor Light socket Black.
  • Amazon.co.uk: dusk to dawn timer www.amazon.co.uk > Search > dusk to dawn timer Amazon.co.uk: dusk to dawn timer. Amazon.co.uk Try Prime All ... Battery Operated Fibre Optic Snowman, Built in dusk till dawn light sensor. Kitchen & Home: ...
  • Feb 05, 2016 | Hardware & Accessories
    I have an Intermatic ST01C timer. Works great. I just noticed that I cannot set the DUSK time past 9:11pm. Any minute before that is fine such as 9:10pm but I wanted to set it to about 9:15pm. It has...
    Call Intermatic.
    You can set dawn-dusk parameters a bit longer or shorter than pre-programmed dawn-dusk times.
    There is a limit to how many minutes you can add or subtract to pre-programmed times, and I'm not sure how many minutes exactly.
    All astronomic timers have limited number of additional minutes, and folks write to fixya occasionally about wanting to extend the limit. But there is no work-around unless you choose to set fixed on-off times instead of using astronomic feature.
    If timer begins to malfunction, you reset timer and change CR2 battery, and then reprogram the timer.
    Instruction manual has troubleshoot checklist.
    Timer comes with 1 year limited warranty.
    Open following links for ez instructions, wiring diagrams, and battery illustration:
    http://waterheatertimer.org/ST01C-program.html
    Jul 29, 2011 | Intermatic Inc. ST01C Digital In-Wall...
    Woods vacation villa 2 room tent manual needed..Please help
    Woods 83660 security timer appears to be same/similar as Coleman 2001/Woods 49647
    Instructions: Timer turns ON automatically at dusk
    Use dial to set 4 possible options:
    Off = always OFF; ON - always ON
    Dusk-Dawn = ON at dusk, OFF at dawn
    2,4,6,8 hours = ON at dusk, lights OFF 2,4,6,8 hours later
    Woods Model 2001-49647 manual
    Jul 10, 2011 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
    I bought two motion sensing diecast lanterns model HB-4190 series, SKU 248-593 and the instructions are hard to understand. To make it easy tell me how to set the device if I want it to come on only if...
    Hello Gerald. Each switch has a function. the the test-1-5-10 allows you to set it to test or an on period of 1 or 5 or 10 minutes. The off-3-6-dusk to dawn allows you to turn it off completely, operate from dusk for 3 hours, operate from dusk for 6 hours or operate from dusk to dawn. By operate I mean turn on and then stay on for the number of minutes you set it to with the other switch.
    what's nice about the test setting is that with it allows you to check and b sure that the light will come on during daylight by setting the one switch to test and the otner to any setting but off.
    If you leave the 2nd switch set to off the first switch will not allow you to test it.
    Joe
    May 22, 2011 | Garden
    Outdoor lights timer: Intermatic HB851 photo timer with dial. How do I set it for dusk ON then off in 8 hrs.
    Intermatic make HB51 timer.
    If this is not your timer, then add a comment.
    To set for ON at dusk, and off 8 hours later, rotate dial to the number 8.
    Timer turns on automatically at dusk.
    Timer set to 8 hours will start countdown when timer turns ON > and 8 hours later timer will turn off.
    Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
    Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on again.
    Feedback from lights will cause timer to reset the 8 hour countdown.
    A car pulling in the driveway can cause feedback.
    If the timer resets because of feedback, it begins the 8 hour countdown again, so the lights will not turn off until dawn.
    You can test timer by putting black tape over photo eye, and then timer will turn on.
    Set timer for 2 hours for example and then check if timer turned off 2 hours later.
    If timer is not functioning correctly, then timer is defective.
    Dec 18, 2010 | Woods Outdoor Lighting Timer
    How do I get it to start at dusk and run for 4 hours
    You posted under Intermatic make HB51 timer.
    To set for ON at dusk, and off 4 hours later, rotate dial to the number 4.
    Timer turns on automatically at dusk because timer has photo eye.
    Timer set to 4 hours will start countdown when timer turns ON > and 4 hours later timer will turn off.
    Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on.
    Feedback from lights will cause timer to reset the 4 hour countdown.
    A car pulling in driveway can cause feedback.
    If timer resets because of feedback, it begins 4 hour countdown again, so lights will not turn off until much later than planned, or not turn off until dusk.
    Dec 18, 2010 | Intermatic Outdoor Timer/Photo Control...
    How do I set it and can I use it indoors?
    I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
    Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
    http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
    http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
    To use timer outdoors.
    Plug timer into wall.
    Timer turns ON automaically at Dusk.
    Rotate dial to set how long timer will stay ON.
    Set timer to turn OFF 2 4 6 8 Hours after dusk
    Set timer to turn off at dawn
    Set timer to ON so lights are ON full time
    Set timer to OFF so lights are off full time.
    Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
    I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL TIMER AND HAVE LOST THE INSTRUCTIONS ON HOW TO SET THE TIMER CAN YOU PLEASE TELL ME HOW TO SET THE TIMER
    That sounds like the Woods 17321 Dusk-to-Dawn yard stake
    Product image:
    http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
    Manual
    http://waterheatertimer.org/pdf/Woods-17321.pdf
    If this is not your timer, check following page:
    http://waterheatertimer.org/Woods-timers-and-manuals.html
    Instructions:
    Yard stake control outlets, and turns ON automatically at Dusk
    Rotate dial to set options:
    Rotate to OFF > outlets OFF
    Rotate to ON > outlets ON
    Rotate to Dusk-dawn > outlets on at dusk and off at dawn
    Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
    Dec 05, 2010 | Woods Outdoor Lighting Timer
    We need clear instructions for setting the timer
    Woods makes several outdoor timers:
    Image that shows with this post is Woods model #49647.
    Below are instructions for #49647 timer.
    If your timer is different, add a comment with model number and I'll post instructions for that timer.
    Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
    There are 4 possible settings that show on dial.
    Rotate dial to make timer selection.
    OFF = timer is OFF full-time until you change dial.
    ON = timer is ON full-time until you change dial.
    Dusk-Dawn = timer turns ON at dusk and OFF at dawn
    2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
    Nov 26, 2010 | Woods Outdoor Lighting Timer
    How to set utilitech wall timer for dusk/dawn settings
    The Utilitec 0192773 timer has astro dusk-to-dawn functions.
    The manual is very unclear at the exact point you need it to say how to set dusk-to-dawn.
    The following page has the manual, with explanation how to find the astro dawn-to-dusk setting
    http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
    When you are programming the timer, press TIME button and hours start flashing.
    Press the +/- button ... the trick is to keep pushing the +/- button until it finally gets to astro, and the sun-moon symbol shows on display.
    When the sun-moon symbol shows, the display also shows AM.
    Press the +/- again and PM show.
    So if you want Program1 to turn lights ON at dusk (PM), then your display needs to show: 1 ON PM sun-moon.
    To continue setting astro, do not set hours, just press PROG button.
    Then repeat the steps above until: 1 OFF AM sun-moon show on display.
    Nov 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
    Malibu Intermatic Inc. ML121RT  Low Voltage 121-Watt Power Pack with Timer Logo
    37 people viewed this question
    Top Malibu Hardware & Accessories Experts
    Gene Haynes
    Scott Jelt
    Scott Jelt
    jdthefixer
    Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
