Question about Noma Holiday Wonderland Multi C6 Led Light Set, 200 Count
Sections of lights do not work
Of one string 2 sections do not light
Armacost ribbon lights are lit for 2 days, then die. Why???????
There is a short in that string. Finding it will be tough but can be done with a meter checking every light in the chain until you find the loss point.
Nov 02, 2016 | Armacost Lighting 12 ft. LED Warm Bright...
Tip
Christmas Light Problem
Finding the Bad Bulblights1b.gif Ideally, the bad bulb will be dark while the rest of the string remains lit. But often that does not happen. The lights in these strings are basically in series, and any open connection, whether in a wire, at a socket, or even inside a bulb, will turn off that whole circuit. Normally the bulbs have a "shunt" which shorts the bulb when it experiences full line voltage. That leaves the bad bulb OFF, and the rest of that circuit ON, which shows which bulb to replace. Unfortunately, the shunt often fails to operate, and then an entire circuit is off. One possibility is to go down the string light-by-light and remove a bulb, test it, then put it back if it tests good. But not only is that a heck of a lot of work, it has the potential to make things much worse: When the string does not light up we cannot know that we have seated a bulb properly. These strings generally have sockets that work well enough as long as we leave the bulbs in the socket. But when we put a bulb in, we may have to try several times before the socket makes contact. Only when the string lights up do we know we have been successful in seating a bulb. So if we are working on a dark string, we might find the bad bulb, and yet have the string still not light because several of the bulbs we re-seated are not making good contact.
on Dec 07, 2009 | Kitchen Appliances - Others
LED Mini-light string stopped working
these lights have what is called a driver it should be either a 12 or a 24 volt DC output this driver can usually be replaced never worked with this specific light though installed the freezer led case lighting at all smiths stores
Feb 09, 2013 | Home
How do i fix christmas tree lights
Assuming the wires to be good, if the string of lights consists of more than one section (for example, a string of 100 lights is made up of two sections of 50 lights each) and the lights of only one section are out, you have a bad bulb (or possibly more than one) that must be located and replaced. If your light string is only a single section set (a set of 50 or 35 or 10), it's most likely also a bad bulb but it could also be one of the fuses located in the plug. Light sets come with a few replacement bulbs and usually two fuses. Take the plug and slide open the little compartment door and you'll see them. Replace them and try the set. If it still doesn't work, it's a bad bulb. On multiple-section sets, the fuses in the plug power all the sections, so a working section eliminates the fuses as suspect.
Dec 15, 2012 | Christmas Lights Etc Santa's Toy Truck
How to cut to size christmas light strings
If you cut the line it would reqier less power so inturn may blow the globes.. it can be done but i woulden advise it if you dont know your electronic basics...
Oct 21, 2011 | Christmas Lights Etc Santa's Toy Truck
1/2 strand of christmas lights do not come on
There's a blown bulb.. take a spare globe & pull out one of the lights that is'nt working on the strand and put the spare one in if the string doesent light up try the next one and so on..
Dec 31, 2009 | Christmas Lights Etc Santa's Toy Truck
We purchased an Everstar pre-lit Christmas Tree and we can not locate the manual or instructions that came with the tree any help since half the tree doesn't light up and all the plugs are plugged in....
I have a 3 piece Everstar 7/12 slim pine and here are the plug portion of the assemblly instructions . "1) connect the plug(A1) of string with the end cord (B1) of string. 2) Insert the plug (B2 & C1) of string into the wall outlet. 3) After the plugs are plugged into the wall outlet your entire tree should be lit. If some bulbs do not light, search for any loose plugs, broken, loose or missing bulbs that may have caused the problem."
My illustration shows the A1 in the top section of the tree while B1 is in the middle section. Both the middle section and bottom section get plugged into the wall or extension cord. Hope this helps
Nov 28, 2009 | Solar Christmas Tree 6 Outlet Foot Switch...
Noma Holiday Wonderland Multi C6 Led Light Set, 200 Count Logo
75 people viewed this question
Top Noma Garden Experts
Dennis Key
Dennis Key
john h
Are you a Noma Garden Expert? Answer questions, earn points and help others
