Question about Dirt Devil Reaction Twin Cyclone Upright Vacuum
The spinning devices no longer spin why - Dirt Devil Reaction Twin Cyclone Upright Vacuum
Brush no longer spins
Apply some Oil or crease in it to lubricate it! it will surely work
Mar 09, 2014 | Dyson DC39 Multi Floor Ball Canister...
Brush stops spinning
the first thing to do is pull the brush and make sure the end caps spin freely. Clean hair and debris from under end caps if they can be removed. Install a new belt if it's been longer than 3 months since it has been replaced. Belts lose elasticity quickly even if you do not use the vacuum,
Jan 15, 2014 | Vacuums
The brush bar no longer spins when I turn it on
I'm sorry to hear you're having difficulties with your Dyson. I can't provide specific advice as you haven't stated which model of Dyson you own - but if you call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), we should be able to resolve this issue with some troubleshooting over the phone.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 11, 2012 | Dyson Vacuums
The spinning brushes on the vaccum no longer spin, how can i fix this? The vaccum picked up a very small wire from a video game and i turned it off immediately. I unwound the wire but the brushes no...
You have either broken the belt or more likely the clutch easiest is to replace cleaner head assembly £75ish or call Dyson and arrange a service if you're not DIY inclined but check belt !st
Oct 31, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My vacuum doesn't have any suction from the floor, only from the handheld attachments. I've cleaned all of the filters with no luck. Any suggestions?
With the vacuum plugged in and running, make sure the brush is spinning and that the brushes on it and long enough that they brush against your hand (or in real terms your carpet). If it is not spinning, replace the brush roll. This will also drastically increase the cleaning ability of it since the new roll will spin faster and the longer brushes will agitate your carpet better.
Let me know if you need more help,
chis
Jun 10, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
Hepa filter does not turn on hoover wind tunnel vacuum model U6630900. It was working (turning) and I cleaned the filter and canister and now it no longer spins when the vacuum is running.
The part you refer to is not the HEPA filter. It's a very common misconception that that part spins - it looks like it when there's dust whirling around it. In fact, it does not spin - there are no visible moving parts.
Jan 07, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Sep 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Dirt Devil Reaction Twin Cyclone Upright Vacuum Logo
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
