Question about Home Security
Grundfos ups 2042 replacement
Need to replace what is compateable
Grundfos pump problems
I've just had a ideal i35 boiler fitted, the grundfos ump3 economic pump has failed / seized and has been replaced 4 times since the boiler was installed 7 months ago.
It has just stopped working again and ideal are refusing to attend.
any advise would be appreciated.
Aug 14, 2014 | Grundfos Pumps Grundfos UP15-29SF 1 12 Hp...
Grundfos stopped circulating.
At approximately $238.95 new, it pays to do a bit of troubleshooting.
Below are some sites that may help:
http://www.plumbersurplus.com/Brands/Grundfos/74
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
There are no repair parts for these pumps, and nobody at Fixya has reported taking Grundfos apart and repairing it.
Jan 21, 2013 | Grundfos Comfort System Recirculator ...
Timer not working on grundfos up-15
1) I have a link for one type of timer replacement.
Have no idea if this fits your specific model.
http://www.plumbersurplus.com/Prod/Grundfos-24-HR-Programmable-Clock-Timer-%28505474%29/11040/Cat/680
2) Above is only repair part I've found for grundfos, and I look for this stuff.
3) You can create a work-around by plugging grundfos into inexpensive wall timer that has 3-prong outlet:
http://www.amazon.com/59366-Appliance-3-Prong-Outlet-Repeats/dp/B001D8VIKE
http://waterheatertimer.org/Woods-timers-and-manuals.html
4) Grundfos system is replaced when it stops working.
If you have hard water, suggest you take pump off and clean with CLR.
Same with crossover located on farthest faucet.
Once motor starts to slow, it overheats and burns out.
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | Grundfos Comfort System Recirculator ...
I have a Grundfos Comfort System. At the tap farthest from the hot water tank, I get a tremendous amount of grainy residue from the tap. No other taps have the residu. I've replaced teh water softener,...
Sounds like you have sediment built up in the pipes, and maybe the furthest faucet is the gathering place.
Take off each shut-off valve at furthest faucet and connect a water hose that flows into nearby toilet bowl.
You can buy garden-hose-to-1/2-pipe adapter at hardware.
Open water so it flushes the line into toilet bowl.
Then clean out valves and reassemble shut-offs and grundfos connection.
Remove faucet aerator and flush line up to faucet.
Install new aerator.
Dec 30, 2010 | Grundfos Comfort System Recirculator ...
After replace the cold water pipe line, my Grundfos recirculator pump does not work anymore. I have to wait 3 min to get hot water. Do you know anything wrong here? Thanks
Many times when pipes are worked on, the work loosens sediment that was built up in the pipe.
Sediment is probably why cold water line was replaced.
That's why faucet aerators get clogged up after pipes are worked on.
It sounds like your grundfos pump got clogged too.
Immediately unplug the pump so motor is not overheating.
Motors are meant to turn freely and can be damaged when blocked.
Take apart the pipes at grundfos pump and see if you can clean out the line.
If line cannot be cleaned or pump doesn't restart, then the grundfos has to be replaced.
Also look at adjoining pipes and see if there is a clog in nearby elbow, especially where galvanized and copper pipes join..
Dec 26, 2010 | Grundfos UP15-10B5/ATLC 1/25 HP ...
I am unable to reset the timer on my Grundfos UP
You were able to rotate it before and you cannot rotate
it now?? Is this the situation??
Then, the programmer is stucked up. Sorry, but you may need to replace it.
Jul 08, 2009 | Plumbing
Clock battery has failed
Yes, I can to slove this problem.
I'm not english people then excuse me for my english. You need a telnet software type hyperterminal in Windows XP, a PC with serial port and a pin-to-pin serial cable. For frist time you need replace the internal battery CR2032 3V of SHR-2042 and erase all content of Hard disk. If you can't erase HD is not a big problem
Connect SHR-2042 with serial cable, open Hyperterminal and create a new connection using this setting:
Speed = 115.000
Bate bit = 8
Parity = nothing
Bit stop =1
Floe control = nothing
Save connection and run it.
Power on shr-2042 and set time and date.
Type "help" for command list
mor more istruction contact me redgerry@tiscali.it
Aug 27, 2007 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Home Security Logo
47 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
