Question about Dell UltraSharp 1504FP Monitor
Dell FP1504 Displaying very dark " Ithink this is backlight issue
Hello Everybody, here is a problem that i've been faceing from few days.
actually, my dell fp1504 15" monotor is displaying very dark...Normaly its screen seems to be dead, but when i put a bright light on screen it seems to be working well but it need a bright behind screen....
as i think! its is a monitors backlight problem,,,,, sometimes it displays automatically well, but sometimes it is dead.... can any body have a solution for this one? if have plaese mail me @
kabir-ahmed@live.com
I have the same problem. I power on the monitor and led-power light turns yellow then finally green but monitor screen is blank. I shine a flashlight on the screen and i can see a faint image. Where is Q7 and Q8 and C5? I can replace.........are they on the inverter board or main board?
Posted on Feb 13, 2010
    Genius:
  • 1,550 Answers
If you are not a technician you can´t solve this problem because are to desasembly your device and check the Q7 and Q8 and C5 that components are on bad conditions and need to be replaced,I told you because i repaired one of these monitors for the same problem
Posted on May 08, 2009
Vizio E480i-b2 LED TV loosing picture and sometimes shutting off
I don't think you had backlight issues like you thought you did as the set should have shut down the backlights totally as soon as it sensed over voltage or over current, I'd try a new main board and see if that fixes things up for you
Dec 09, 2017 | Vizio Televison & Video
Insignia LCD TV screen goes black until hit.
Try to follow the inverter to backlight connections---either a loose or damaged plug (look for any plug with tape on it at the plug first) or on the board that powers the lights a bad solder connection or connections where plugs connect.
Oct 29, 2012 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
Dell Latituse D600 display goes dark
The picture board on your monitor is faulty or bad, since it goes black after few seconds, it means the picture board of your laptop has developed fault.
The best thing for you to do now is to take the laptop to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | Dell Latitude D600 Notebook
My monitor goes dim after a few minutes. When you switch it off and on again the dsplay is ok then becomes so dark
How dim is dim? If the picture is still visible just like half as bright then your have backlight tube problem and unit LCD needs to be replaced, not worth repair price. If the picture goes out almost to a black screen where you can just bairly see a faint image then you hold the screen just right then you have a backlight inverter issue. If the problem is the inverter then you should be able to replace a few parts and get your unit back going. If you think you can open the unit up and maybe solder a few parts then I would open the case and look for bad capacitors on the power supply board. I can send you pictures of what to look for if you are interested. We also have a repair service for those units, most power issues run $15.00 plus shipping. Let me know if you need help opening the unit and checking parts.
Jun 17, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
My dell inspiron 1520 has dark screen
If you replaced the backlight and you still have the same problem then the next step you should take is to replace the inverter.
That should solve your problem, if it doesn't let us know.
Mar 04, 2009 | Computers & Internet
Dark Screen Inspiron 9100
If you replaced the inverter board and its still dark you need and new backlight itself http://cgi.ebay.com/LCD-Backlight-Lamp-for-Dell-Inspiron-9100-15-4-WXGA_W0QQitemZ150217509448QQcmdZViewItem
Dec 10, 2008 | Dell Inspiron 9100 Notebook
Laptop screen goes dark after booting .
your issue with your laptop is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google.
They are cheap to replace google your model with inverter at the end..
They are not too hard to replace
Nov 21, 2008 | Dell Latitude CP (0001849d-38380-968-p06e)...
Two days ago I turned my computer on and where my sidebar gadgets should be there were black squares and rectangles. My clock was square with a black face and not working. I tried installing different...
Hello Donpd,
I have the solution to resolve the issue.
Perform the steps as provided below:
1. Close windows Sidebar. Right click on the Windows Sidebar notification area icon and click Exit.
2. Open the Start menu and click All Programs, then click Accessories. Right click on Command Prompt and click Run as administrator.
3. In the command prompt, type "regsvr32 msxml3.dll" without quotes and press Enter. Then click Ok.
4. In the command prompt, type "regsvr32 scrrun.dll" without quotes and press Enter. Then click Ok.
5. In the command prompt, type "regsvr32 jscript.dll" without quotes and press Enter. Then click Ok.
6. Turn Windows Sidebar back on.Check to see if Windows Sidebar is displaying correctly now.
Sep 10, 2008 | Computers & Internet
My acer laptop screen is dark
If your laptop screen is dark, it could be the backlight,inverter, or bad lcd. You can test the backlight by starting the laptop and give it a few seconds to load and take the laptop in a dark room and shine a flashlight on the lcd and see if you can see any pictures or icons. If you can, you may just need an inverter to correct the issue, If not, you may need to replace the inverter and lcd both.
If you find that you need parts to correct the issue. I would suggest that you begin with replacing the inverter first, as they are usually less expensive.
If you can supply me with the model number of the specific laptop you are having trouble with and I can try to locate more information on replacing the parts.
Thanks
Jul 23, 2008 | Computers & Internet
Computers & Internet Logo
598 people viewed this question
Alun Cox
