How to reset the error code SC534 on ricoh c320dn printer
SOURCE: Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
SOURCE: error sc542
"clear modes", 1, 0 , 7, then (hold) "clear/stop" for a few seconds until "sp mode" comes up. turn main power off/on (red switch).
If code comes back there is trouble with the fuser that needs to be repaired to clear code permanently.
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
SOURCE: Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
SOURCE: have ricoh 2027 - printer error code sc542 - how
ves revisa el tesmistor, el fusible que esta al lado hizquierdo del tesrmistor o si no pruba la continuidad de la lampara fusora que puede estar abierta despues de esto entra al modo de servicio, engine, luego al punto 5.mode despues con las flechas de arriba abajo localiza sc reset le das enter, prendes y apagas y problema solucionado espero te allude esa fue mi solución y te cuento que esta trabajando la lampara fusora estaba abierta.
