Question about HP Photosmart 5514
Hp photosmart doesn't print black even with new cartridge
Printer was working fine, went on vacation and now the one cartridge (black) doesn't print. Replaced cartridge same problem
  • 3 Answers
SOURCE: K550 printer not printing Black
hi there is a simple solution to your problem take out the print head place just the jets( where the ink comes out) in warm water for a few seconds while it is in the water use a syringe over each breathe hole at the top of the print head (one at a time) and lightly push air into the head. this process clears any ink clog and frees up the print head and allows it to print propely
Posted on Mar 05, 2009
SOURCE: Can't scan on HP Photosmart C4380 even tho printing works fine
I am sick and tired of the problems i have with this PSC, but i have found a scanning solution and thought i would share it.
Use Microsoft Paint. It's not the best application in the world, but you can insert a scan from a scanner in the 'file' menu. :0) The scans are not of the best quality, but i'm grateful i can scan at all with this useless PSC.
Posted on Apr 18, 2009
SOURCE: HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Posted on Jun 16, 2009
SOURCE: My HP photosmart 7660 won't print black.
clean the connector between the cartridge and the brownish part in the printer where the cartridge touches. it might be dirty and thus not enabling the connection with the black
Posted on Aug 19, 2009
SOURCE: HP photosmart C4480 printer cartridge incompatible error
Well....I solved the problem......bought a new Canon printer!!
I tried everything...unplugging, cleaning everything that was mentioned above. I was onto HP online support several time, but they were absolutely no help at all...they basically told me that the cartridge must be damaged or ink dried up and to buy a new cartridge to see if the error persisted.....I don't think so!!!
I will never by HP again after having issues with the last two I have had. I love my new Canon printer it is EVERYTHING that HP wasnt.
Posted on Jan 16, 2010
I have an HP Photosmart 2575 all-in-one printer, and my black is not working I just replaced it with a new cartridge and it still doesn't print the black.
The new ink-cartridge probably is OK.
So, start the HP Printing Assistant Software, and run the "Print-Head-Cleaning" utility, to run a few cycles. Hopefully, it will unclog the ink-jets that _should_ be spraying ink onto the paper.
Jul 25, 2011 | HP Office Equipment & Supplies
My HP photosmart 3210 skips lines on the black ink only. The other colors print fine.
(The obvious) Replace the black cartridge. Even if ot says you have ink you could have a faulty cartridge, even if it has worked fine in the past. (The not so obvious) Clean your printheads/nozzles. Repeat the process a few times.
Apr 27, 2011 | HP Photosmart 3210 Printer
Have a hp photosmart premium c309 and have changed the ink cartridge and the black ink is not printing well. All the other colors prink well
HP Photosmart Premium C309 not printing black
Got that problem also, Black would not print but dark grey would be printed ???
What i did and it worked was reset to factory settings, unpluging the printer for ± 25 seconds
holding 3 and # for and other 25 seconds went and after pitting power back on
then re-enterring your setting, all went fine
http://h30434.www3.hp.com/t5/Other-printing-questions/Photosmart-C309-suddenly-stopped-printing-black-ink-any-solution/m-p/495549#M30719
Hopping this will help others
Nov 10, 2010 | Office Equipment & Supplies
Aug 19, 2009 | HP PhotoSmart 7660 InkJet Printer
HP 3310 ink cartridge not recognised
My HP 3310 wil not print black. The color prints fine. Spent 2 hours on the phone with HP support only to be told to buy a new printer. The machine is less than 2 years old. There must be a way to repair this. Any ideas? Barbara
Nov 08, 2007 | HP Photosmart 3310 Printer
HP Photosmart 5514 Logo
Seeker5211
Seeker5211
