Question about Xerox DocuMate 152 Pass-Through Scanner
WHERE DO I GET A WHITE REPLACEMENT STRIP? - Xerox DocuMate 152 Pass-Through Scanner
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Search on this website
DocuMate Scanners from Xerox
Posted on Mar 19, 2016
NEED WIRING DIAGRAM FOR SONY CDX-GT520U
red - ignition switched 12 volt
yellow - constant power 12 volts
black - ground wire
orange - dimmer wire don't use
speaker wires
drive side front
white +
white/black strip -
passanger front
gray +
gray/black strip -
drivers rear
green +
green/black strip -
passanger rear
purple +
purple/black strip -
blue - remote amp turn on wire
blue/white strip - either power antenna or remote amp turn on also
radiorepair@windowtintingin239.com
Oct 30, 2013 | Car Audio & Video
I need a replacement power switch for model 9000w living pure 4-in-1 unit.
Remove the filter in the back. Unplug the four wires that went to switch. (2 black and 2 white) Cut metal ends off. Strip ends with wire strippers. Connect the white to the white and black to the black with wire nuts. Wrap with electrical tape. You've just bypassed the power switch. Now have a cocktail! You're done.
Sep 14, 2013 | As Seen On TV Living Pure Pro Series...
Had the tail light assmbly (drivers side) on my 2006 chrysler t&c stolen. Took the plug too. I got the repair parts but cannot figure out the wiring. Four wires. Black with green stripe white with...
Not sure I follow your question. The replacement lamp assembly did not come with the wiring for the lights ?
According to the diagram, white lite green is the backup lamp, black dark green is ground, white brown is the parking light, and white dark green is the turn signal or brake light.
Jul 13, 2013 | Cars & Trucks
Wire lose from starter how to put it back?
Vicki, If you unplug the wire from the socket and cut it leaving a couple of inches still on you can take it to the dealer or to a junkyard and that will get you a replacement wire. Strip the wire that you left and strip the end of the new wire. Go to a auto part store and buy a "**** connector". This is a small tube that gets crushed around the wires. Tape the two ends where the wires are and you should be good to go. I hope that this helps.
Oct 12, 2012 | Cars & Trucks
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
I've bought an adapter thing, but I don't understand how to wire these wires.
  • Yellow - To the car battery of continuous +12VDC
  • Red - To ACC Power, +12VDC
  • Black - Ground, to bare metal or clean part of the car
  • Dark Blue - Motor Relay control lead for Antenna
  • Dark Blue / White Strip - Amp Relay Control lead
  • White - Front/Left Positive Speaker
  • White / Black Strip - Front/Left Ground Speaker
  • Gray - Front/Right Positive Speaker
  • Gray / Black Strip - Front/Right Ground Speaker
  • Green - Rear/Left Ground Speaker
  • Green / Black Strip - Rear/Left Ground Speaker
  • Violet - Rear/Right Positive Speaker
  • Violet / Black Strip - Rear/Right Ground Speaker
Nov 11, 2010 | Panasonic CQ-DP133U CD Player
What is this mean
In the scanner unit of the copier there is a white strip that is usually located under the main glass(depending on copy model). The copier shines light (from the bulb on the scan carriage) onto this white strip and reads/measures the reflection coming back from it. The copier knows that this strip should be white (which would be specific value stored in the copier) so to maintain copy quality the copier keeps referencing this strip to make sure it keeps the "white" value and does not loose sight of what white is supposed to be. If the strip becomes dirty/faded/scratched or missing a piece then you will notice a drop in copy quality.
If you were to stick a small black piece of tape onto the white strip the copier will still think that the black tape is supposed to be white but its value in reading the black tape will be completely different to the value it receives from the rest of the white strip. If you now made a blank copy you would get a black line showing up corresponding to the place where you stuck the black tape. BUT the copier still thinks its all white.
May sound a little confusing? but that's the just of it.
Jan 14, 2009 | Sharp AR-407 Copier
Replacing 7 wire towing plug on f150 ford truck 2002.
Green=R/H flasher
White=Battery Neg -ground
Yellow=L/H Flasher
Blue=Battery+(Some times used for caravan lighting supply)
Brown w/ white= Trailer electric brakes.
Hope this helps...
Jul 26, 2008 | 2000 Ford Focus
RE: SENDING FAX
The scanner glass is dirty or needs replacement. lift up the scanner door where you put original in. See the glass strip 1/2 inch by about 8 inches. clean with alchohol good. dry. test. Lawrence
Jul 18, 2008 | Sharp FO 77 Roll paper Thermal Fax
Xerox DocuMate 152 Pass-Through Scanner Logo
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
