Question about Philips Audio Players & Recorders
Philips subwoofer sw090 has no sound.
No sound, only humms, fuses are good, capacitors look good green led light comes on
5 Suggested Answers
  • 50 Answers
SOURCE: No sound comes out of the subwoofer. Sound passes
this may be a dumb question but have you turned up the signal. there should be a dial on the back that you can turn the power up. power light on, signal passing threw, the only other thing it can be is the built in amp itself may be dead.
Posted on Aug 09, 2009
budmrtn
  • 11361 Answers
SOURCE: JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
Posted on Nov 10, 2009
  • 19 Answers
SOURCE: the subwoofer just quit working
if the light still comes on then the fuse is still good....
a possiblity exists that either the amplifier or the actual speaker itself went bad....if you like you can dissasemble the the subwoofer to access the insides....a simple test....if you connect the driver to another amp (any amp will do as this is just a test) and it makes sound then chances are your amp is bad or just a loose connection.
Posted on Oct 28, 2010
SOURCE: JBL Venue SUB10. LED light
This usually indicate a power supply rail, failure, and or a main amplifier has "Blown". You need to take this unit into a JBL repair shop, contact a local or head office of JBL, and ask them for a referral to an authorised service center. When in face to face contact here, ask them only and first off for a "Quote" as to the prospective repair costings and go from there?
Posted on Jul 30, 2011
No sound or "green" light
Your power supply have a problem. Check the FF:
1. Power cord - might be open due to frequent bending and pulling.
2. Power switch - for open contact.
3. Internal Fuse might be open. If open replaced with exact ratings. If the new fuse blew again this is an indication of shorts in transformer, Rectifier Diode, Main filter capacitor, output IC.
#3 is technical and you must have knowledge in electronics, have tools and test instrument to perform the steps.
Hope it may help you.
Give a thumbs up if you find it useful.
Have a nice day!
Feb 07, 2011 | Philips Audio Players & Recorders
The subwoofer just quit working the green light is on sound comes out (here voices) the subwoofer no bass
Aug 30, 2010 | Sony SA-VF700ED Speaker
Philips Power supply flashes 5 times
one day not start his open. stan by red led and after switch on ,his green bligkig is not open.sound is ok.(the relay his not click)
Apr 12, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
Philips Brilliance 200w6cs Backlight off Green LED ONN
Check to see at one of the pin on the inverter board has 12vdc feeding it. No bad capacitors? Pictures?
Nov 29, 2009 | Philips Brilliance 200WP7ES - Flat panel...
NAD C352 turns on but no sound
The first and easiest things would be to check all connections.
Speaker wires
RCA Cables !!
If you are getting a green light you are getting proper power and ground connection.
Other than that the other possibility's would be internal components, capacitors ect.
I would be willing to bet something has come jarred loose. Post back after you have checked and double checked all connections.
Aug 12, 2009 | American Pro VS-2043 Car Audio Amplifier
Infinity Entra Sub 150 no sound or power
I had the same problem. When I opened it up, the fuse was blown, and it was a pain to find the fuse it needs (3 Amp, 250 V slow-blow fuse, 5x20 mm). Also, the 2 large electrolytics (big purple things near the amp) and one small capacitor were all blown. For 4 fuses, bought seperately from, and the 2 electrolytics and 1 capacitor, it cost about $20, plus almost 20 more in shipping, which still isnt bad considering the original price of the sub. However, the tricky part is that you have to know how to use a soldering iron to take out the old components and put in the new ones.
Jan 01, 2009 | Infinity Entra Sub Subwoofer
Philips HTS 3450 sound
I just blew my subwoofer up. The fuse was blown so I rigged it with something to act as a fuse, and the thing spewd out a volcano of smoke! Oh well..
Sep 21, 2008 | Philips HTS3450 System
Audio control pod
I have a similar issue too, but my problem is that the sub has green light, and my control pod has an 'off' light, but it won't turn on :(
Jun 16, 2008 | Creative Labs Gigaworks S750 Computer...
Philips 42PF7220A 42 in. Plasma
I had a Similar problem where I would turn the tv on and the green light would come on and then the red would follow and blink 7 times. I tried unplugging it and then then replugging it back and it would still do the same. What I did last night was that I unplugged it and then replugged it back, when I saw the green light, I would unplug it again, till the light went out and replugged it, I did that 3 times in a row, and waiting and it came back on. Hope that works. I still don't know what caused the problem to begin with..
Oct 27, 2007 | Philips 42PF7220A 42 in. Plasma Television
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
59 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
