Question about ILuv MobiAria Bluetooth Speaker
Iluv mobiaria has parameter error
Iluv mobiaria bluetooth speaker parameter problem
Why my nabi2 pear with my iluv speaker but can't hear it ?
Pairing and connecting are different steps in the process of connecting two Bluetooth devices. As long as your headphones are not CONNECTED (not just PAIRED) with your tablet, you are not going to hear anything that you play on the tablet (music, video, etc.).
Jan 22, 2015 | ILuv Audio Players & Recorders
Why my nabi2 is pear with my iluv speaker but can't hear it ?
Probably because they are PAIRED, but not CONNECTED. Pairing and connecting are two different steps in the process of making two Bluetooth devices to communicate with each other. Read the manual on how to connect the two.
My Iluv Alarm with shaker for Iphones won't play any music when I try to connect it
do you have it set to the correct input?is the volume up on the phone and iluv?is the iluv device powered.is the iluv device turned on?is the iluv device compatible with you iOS device?Return the iluv device if all else fails it should work, also try using the aux port, many ios devices in fact will charge with other devices however not all iOS devices will interact with other devices, have more questions? just ask
Mar 29, 2013 | Audio Players & Recorders
Imm727 will not charge ipad, i phone.
I have the same problem and found no solution. I realized this issue after upgrading to iOS7 iPad. With iOS 6 functioned normally to load, then not.
Mar 09, 2013 | iLuv Creative Technology iLuv iMM727...
No sound from iLuv i9200WHT music center 3.15amp fuse keeps blowing
The problem is more than likely in the audio output chips in the unit, check to make sure the speaker wires are not shorting.
May 16, 2012 | Jwin iLuv i9200 Shelf System
I lost the manual, and I can't work out how to set the time or alarms.
Follow the link below to a website that has the manual. It will ask you to submit to some optional services, but I know you can just reject it and the manual will come right up.
http://portablemedia.manualsonline.com/manuals/mfg/iluv/i177.html
Jan 03, 2011 | Buck iLuv i177 - Alarm Clock Radio With...
O not know pin number
The pairing pin is 0000
Hope this helps,
levibit
Dec 19, 2010 | Jwin Iluv I120 Bluepin Bluetooth(tm)...
Failure to sync
hi, there maybe interference with the signals try in a differnt area.
Aug 04, 2009 | Jwin iLuv i903 Consumer Headphones
ILuv MobiAria Bluetooth Speaker Logo
Top ILuv Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an ILuv Audio Player and Recorder Expert? Answer questions, earn points and help others
