Golden tee 2005. Will only start up then say hard drive detected then surge then the screen goes blank. Just moved to another state. Any ideas
    Top Expert:
  • 12,223 Answers
Please see the flowchart troubleshooting for fix it. God bless you
Golden tee 2005. Will only start up then say hard - 529827f9-06f8-412c-842e-7f2007e77961.gif259e9086-8461-46f6-b532-8ba1426953ac.gif
Posted on Nov 26, 2013
4 Suggested Answers
VirtualD
SOURCE: Blank Screen
id say its hardware. try pulling the hard drive out and checking to see if posting gets any further.. it also could be the cd drive causing the post hang.
Posted on Dec 20, 2007
  • 86 Answers
SOURCE: Screen goes blank at start up
Its failing to go through the full boot process. Try pressing F8 on boot until the boot option screen comes up and then select safe mode. Follow this though until you are given the option of using system restore instead of safe mode. take that option by clicking on the NO button. Restore the machine to a date some time a few days previous to the fault developing.
If that fails then put in any OS disc and boot from it. select R at the first options screen, follow it through and then select the C drive option. Just hit enter when asked for admin password.
now type chkdsk /r (copy and paste this to be sure). let it run and then reboot and see what happens
Posted on Dec 15, 2008
  • 69 Answers
SOURCE: Eee Pc starts with blank screen.
it could be a ram issue. if you're proficient with your hardware and the lappie is out of warranty try removing the ram sticks then re-seating them. this resets the ram and allows the monitor to turn on
Posted on Feb 25, 2010
When I boot the computer, I am able to get into the bios config by pressing the del key. But Once the operating system starts to boot up, it goes blank. The little grey bars on the bottom moves, but then...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your hard drive from the motherboard or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Dec 22, 2010 | Soyo P4I 845PE Lite (SYP4I845PELITE)...
I have a 2005 golden tee tournament edition, when i turn it on it powers up but the screen is blank, any suggestions???
First you will need to open your game arcade machine and check the Game Motherboard cables and connections, check all plugs, every connector, reconnect all of them..and try to turn it on again!
After doing this try to check your power supply and see if it is working well..
see if the board look´s like this:
Note that some versions has ide hdd interface.
to help you, i find the service manual with all the instructions in this link
There is a step by step guide to fix your Golden tee!
Good Luck!
Dec 07, 2010 | Arcade Golden Tee Unplugged Video Cabinet
I was using my netbook on the internet and got a message that I had a hard drive issue and the screen went blank. When it loads from the strat up it goes to a bios screen and then dark with a blinking...
check BIOS if it detects a hard drive. if not, try to manually detect it. if it fails, it is a hard drive problem
if it was able to detect a hard drive. you should be able to do a system restore. Read the manual that came with your netbook for full instructions and illustrations on how to do a system restore.
Nov 07, 2010 | Computers & Internet
Golden keeps rebooting
Vandre's suggestions are very good.
Some boards are fussy with voltage and need a small adjustment to find the setting they like best.
You can put the board into test mode/menu when you power it on, refer to the manual on how to do this, and see what the current voltage is being supplied to the board.
5.2 volts DC is a good setting for fussy boards. If it still reboots try 5.4volts, maybe 5.6 volts, but recommend going no higher than 5.6.
This will compensate for voltage drop across the board to getvit through the startup cycle.
Hope this helps.
Jan 24, 2010 | Arcade Golden Tee Unplugged Video Cabinet
When i turn the power on, the screen says detecting hard drive and then goes blank, no music or anything after that, but the golden tee complete sign above is still lit. thank you for your help
your harddrive is broken. the solution is buy a new harddrive. I hope you have a backup of your harddrive. if you haven't that you lost al your files.
it's hard srry but your harddrive is broken.
Aug 28, 2009 | Video Game Consoles & Games
Blank screen
Any hard disk that makes clicking or metallic noises is faulty, especially when POST error message no bootable devices detected.
To confirm go into the BIOS setting and see if the hard drive is detected, if it cannot detect the hard drive then it is definitely faulty.
Replace the hard drive and install Windows on the new hard drive to get the computer working again.
Aug 01, 2009 | Toshiba PSAFGU-058002 Notebook
Toshiba satellite screen blank
This could be that the hard drive has failed, and could also be the reason for the initial crash. Run a drive test in the bios or set up. If the test fails in any area then the hard drive is bad and will need replaced. If it passes, then reformat the drive and reinstall XP.
Jul 29, 2008 | Toshiba Satellite A100-S8111TD Notebook
Blank screen on start up
It means that your system cannot detect Windows on your hard drive. Check the connections inside if you can. If everything is connected properly, then your hard drive is probably is at fault. You can do a disk check in dos but may not be accurate.
Oct 30, 2007 | Compaq Presario M2000 Notebook
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
