Question about Husqvarna Viking 1
My Viking 980 sewing machine does not catch far right stitchs. I would like to fix it myself. I have been advised it is likely a timing or needle position problem.
  • 1 more comment
  • bagaduce May 12, 2009
    Is this where I post clarifications for radcal from bagaduce?
    I was able to "fix" my viking 980 by putting the needle in a bit lower.
    Now I would like to lower the bar correctly rather than cheat the machine. Is this a simple adjustment? Does it require removing the casing. If so, how?
  • bagaduce May 17, 2009
    There are no authorized repair techs in my area. I located the screw to raise the bar and my machine seems to be running fine now, hopefully. Thank you.
  • radcal May 11, 2010
    I agree with either timing or needle position. Have you measured either?
    Novelist:
  • 192 Answers
It could still be either problem. Lowering the needle is kind of like curing a cough by not breathing. You still don't know if you have bronchitis or emphysema, but you will stop coughing.
Is the needle centered in the plate side to side?
Does your zigzag have equal clearance on either side in the plate?
Check timing by lowering needle bar to lowest position and then raise it 2.5mm, push the hook back into the driver and the tip of the hook should center on the needle. (raising the bar 2.5mm is easily done with a setting gauge available to authorized technicians)
If timing is correct, set the needle bar height by loosening the screw in the cross head and adjust the bar up or down so that the hook crosses above the eye of the needle while in the far right needle position.
Adjusting the bar height will be the equivalent of lowering the needle but check the timing first. If it is off, the machine will sew but the stitch quality will be poor.
You really should try to find an authorized repair technician in your area. If you change the wrong thing you may make the problem worse and it will just cost that much more when you have someone fix it for you. Also, the tolerances are very close on these adjustments. You may thing that raising the needle about 2.5mm is close enough on the timing check. For that measurement, there is no tolerance. If you go to 2.4 or 2.6 your stitch quality will suffer.
Posted on May 13, 2009
Recently my sewing group was given Husvarna Viking Emerald 116. Stitch width is off.
Be sure and use the correct sewing foot...the machine is probably reading the foot and won't let you make adjustments. Also make sure the needle plate is the correct one.
Jun 01, 2016 | Husqvarna Viking Emerald 116 Sewing...
I can't get the bobbin thread to catch. I have tried changing it and swithing needle positions/tension. Nothing seems to do it.
Most of the time that means that the timing of the machine has become off for some reason. The timing is when the needle catches the bobbin thread. If that is not right it won't catch the bobbin no matter what stitch you try. Unfortunately there are about7 different adjustments that it could be that will fix it. You can try talking to the people at the link that I attached or you may have to bring it in to have someone professionally adjust the timing. Good luck. Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Feb 04, 2015 | Sewing Machines
How do I set the dials on husqvarna viking 6000 sewing machine
The "dial" in the back is for decorative stitches which require a "programmer" to be inserted with the stitch formation you want to form. For a straight stitch no cam is required in the back of the machine. The three dials on the front:
Upper Left: Stitch selector
Upper Right: Stitch lenght
Lower: Stitch width
Using the upper left dial select the straight stitch picture
Using the upper right, choose your stitch lenght
Using the lower, choose your needle position, left/center/right
Dec 13, 2014 | Husqvarna Sewing Machines
Why is my Husqvarna Viking 425 not forming stitches
1. Make sure there is bobbin thread. 2. It is very important to have the bobbin thread with the right tension setting. This is done by hanging the bobbin carrier with the bobbin inserted from your finger. Bob it a little and it should extend one inch. If it doesn't extend then loosen the tension(counterclockwise) and opposite if it extends too far. 3. Afterwards insert the assembly and pull a couple inches of thread out. 4. Now, thread the top. 5. Adjust the tension to three. 6. Run three inches of thread under the foot and hold unto the thread. At the same time turn the crank towards you. When the needle goes under the plate and back up it should have the bobbin thread with it. Sometimes the first turn doesn't catch the bobbin thread so try a second time. If this doesn't work then change your needle just in case this is the problem. If this doesn't work you will need a repairman adjust the timing.
Oct 29, 2014 | Husqvarna Viking 1
I have memory craft 6000 janome,i have been told it could be a timing problem.how can i diagnose this
try sewing a wide zig zig stitch and check the stitch formation, is it catching on both sizes of the zig zag or perhaps only one side.
Timing out means that the timing sequence between the needle going down to its lowest point is not in sync with the rotary hook coming around behind the needle to catch the thread tail behind the needle eye.
You could also remove needle plate, sewing foot and bobbin, and hand wind the flywheel through a stitch sequence and watch the needle and rotary hook movements. When the needle is at its lowest point, the rotary hook should be right behind it.
Adjusting timing is not something I would tackle myself though, I leave that to the technician.
Jun 06, 2011 | Sewing Machines
How to thread a double needle on a Husqvarna, Platinum 715?
You need two thread sources. This can be two spools or one spool and a bobbin on the spool pin.
Make sure the presser foot and needle plate openings are wide enough to accommodate the passing of the needles.
Lift the presser foot and beginning with the thread source to the far right, thread as usual through the right needle, then the left needle.
Make sure to use a straight stitch and you may have to loosen the tension a bit (test).
Hand walk the needles down and back up to catch the bobbin thread. Take all three threads under the presser foot and to the back of the machine.
Mar 17, 2010 | Husqvarna Viking 1
Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
May 24, 2009 | Husqvarna Viking 1
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
Needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
Mar 26, 2009 | Husqvarna Viking 1
Sewing Machines Logo
351 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
