I have a heat pump goodman model cpkj36-1ab what tonache is this
CPJ18-1B Goodman heat pump. has a slow leak. I need to know what Ton or BTU to replace it with.
you have a 1.5 ton. 12000 btu's per ton. your model number has an 18 in it. tells you 18000 btu's
Apr 13, 2017 | Goodman Heating & Cooling
What is the compressor part number for a Goodman heat pump model PHKJ036
ZR32K5EPFV800 is the OEM part number. I have to ask why you believe the compressor is bad.
Feb 24, 2017 | Goodman Heating & Cooling
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
I HAVE A GOODMAN HEAT PUMP, MODEL AR30-1. I switched off the heat pump at the stat and the elements seem to be running heating up the unit... Also what is the brown wire coming from the wiring harness for...
The brown wire on a Goodman is tipically for the emergency heat option on your heat pump. First thing I would check is making sure it is wited correctly. Verify your stat is heat pump capable. Many of the cheaper stats only work for ac or just a heat pump. Anything beyond that would be a more serious electrical problem and should be looked at by someone with the proper training and tools.
Feb 11, 2011 | Goodman Heating & Cooling
We live in SC, have a Goodman 4 ton split system w
First of all is this unit a heat pump i'm not up on goodman model #'s if it is a heat pump reversing valves do go not a real common problem 1000.00 is excessive i would be inclined to get a 2nd opinion. plastic over the sand could create a condensation mold problem. Good luck. Tom
Jun 23, 2009 | Goodman CLQ36AR49 Air Conditioner
I need to find a parts dealer for goodman heat pumps.
let me know where you live and I'll find you a dealer
Jun 16, 2009 | Goodman CKL60AR60 Air Conditioner
Service manual for Goodman Heater # PGB036100-1
sounds like that model # is for the A/C coil or its a heat pump air handler. In any event I am not aware of any "repair manual" that is put out by Goodman to the public. They have classes on their equipment but they are geared to the professional serviceman.
If you would like to descrobe the problem, I will try to help you.
Nov 03, 2008 | Goodman GMS90703BXA Heater
Goodman heat pump
all waranties are different. check on-line at the goodman site and check your warranty info, on your model
Jul 14, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
