Paper jam I have a family member that has a Canon F237603 large copier. When it copies, the paper goes almost all the way through, but as it is coming out the other side, it jams up and the paper bunches up. Any suggestions would be greatly appreciated.
First of all...that number is not the proper model number, so clarifying that might help further, but regardless, the paper is getting jammed in the fuser and it sounds like it probably needs a heat roller and/or pressure roller replaced, and possibly the picker fingers
Posted on May 12, 2009
Spilled milk Cleaned it up but now when I try to print paper goes in crooked and jams -
Examine the paper guides looking a any paper jam and remove.
Paper jams are sometimes difficult to remove without disassembling
the printer.
However you could try using card stock as it is firmer and may push the paper jam from the printer, if this fails call one of your computer literate family or friends to help. As most printers are not to expensive, I will not suggest any repair shops. The cost of a printer is in most cases less than the the cost of the replacement ink cartridges.
Feb 19, 2016 | Canon Ink Cartridge for Pixma MP252
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
The paper won't feed and the paper jam light goes
Wich copier model do you using?
My wild ques would be paper feed rollers. Try to clean them with alcohol and try to copy.
But still I would want to know the model.
You can also contact me on emma.servis@gmail.com, if its Canon copier.
Jul 17, 2010 | Canon Office Equipment & Supplies
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
No paper jam and no copies
check the fixing ***'y
Aug 05, 2008 | Canon PC-795 Copier
Canon 6050 copier
yes it indicates same message
Apr 14, 2008 | Canon NP 6050 Copier
Paper Jams
How many copies has the copier done ?
When was the last fuser fitted ?(heated rollers)
the fuser rollers have a life of about 100,000 copies
and you change the whole unit at 200,000 copies
Feb 15, 2008 | Canon imageRUNNER C3200 Copier
PC-795 Shuts Off Mid Copy
clean big rubber paper feed roller above paper tray with a microfibercloth moistened with rubbing alcohol.
open copier look in lower section under the toner cartridge you will see a black foam roller wipe it off also and then try to use.
Jan 17, 2008 | Canon PC-795 Copier
54 people viewed this question
k24674
jasbo
jasbo
