Rhine ceiling fan remote replacement
Model: UC7083T need remote control
  • 15 Answers
SOURCE: no connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Posted on Apr 17, 2008
  • 14 Answers
SOURCE: Two ceiling fans, both remotes control the same fan
One of the dip switches is located under the globe, near the ceiling.
The other dip switch is located in the remote control. You have to take the battery out and look in the space where the battery is, usually towards the top of the remote.
On mine, there are four settings, the dip switches have to be in the same position, on both your remote and the fan unit, for them to work. You might have to reset them if you do not want both fans to work from one remote. Maybe one fan and remote have the first switch up and the other three down, that would let them both connect. The other may have the first one down and the others up, then it would only work from the remote that is set the same way.
Usually you can reset them by using the point of a pencil to move each dip switch setting.
Posted on Mar 26, 2009
  • 10865 Answers
SOURCE: i bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Posted on Jun 20, 2009
SOURCE: Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
Posted on Aug 09, 2009
MN_Jack76
  • 45 Answers
SOURCE: fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Posted on Oct 17, 2009
My remote controlled Hampton Bay ceiling fan light partially works. The fan works but the light does not. The remote control is a Rhine UC7076. Any ideas in making the light work? Also where can I buy a...
That's a low-end store brand for Home Depot only. Sounds like you need a new receiver. Make sure if you have a pull chain on the light that you pull the chain to the on position.
Dec 07, 2014 | Hampton Bay Dryers
I have the Hampton Bay Ceiling Fan and Remote. Model UC7083T THAT DOES NOT WORK.
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
Jul 18, 2014 | Universal Remote Control Hampton Bay...
Where did you find the little black box?
Apr 16, 2014 | Dryers
Hampton bay uc7078T remote with uc7083T receiver ?
read your instruction manual download from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 29, 2012 | Universal Remote Control Hampton Bay...
I have a hampton bay ceiling fan/light and the remote came with it. The remote model is: UC7083T. The battery died and when I installed a new battery, the remote willnot connect with the fan/light. Any...
try turning off the switch/circuit breaker at the main lighting panel. Then just turn it back on. Worked for me.
I'm guessing a capacitor in the remote is holding a charge and causing the problem. You'll probably need a new remote soon thiough.
Nov 27, 2010 | Universal Remote Control Hampton Bay...
Need part: Rhine Fan Speed Control Model:UC7058RY Where can I get one?
I need a RHINE fan speed control model uc7058ry 7058gy-05 part. Please tell me where I can get one
Oct 18, 2010 | Hampton Bay 60 In. St. Regis Fan, Ancient...
Fan speed control UC7058RY produced by RHINE, need to order replacement? For St. Regis 60" Hampton Bay Ceiling Fan.
hi Januszkop,
I have the same ceiling fan. However, I lost the remote control. Do you know where I can buy it? Thanks.
Oct 24, 2009 | Hampton Bay 60 In. St. Regis Fan, Ancient...
I bought a hampton bay ceiling fan model uc7083t but i didn't
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
